Old 12-30-2014, 11:31 PM   #826
Ran into a small problem with the build.
The standard rear arms bind when using the 1mm shims front and rear as suggested in the manual. Using the 0 inserts.
A thinner shim removes the bind but this doesn't match the manual.
Not a big issue but I just want to make sure I haven't made a mistake.
DamianW is offline   Reply With Quote
Old 12-30-2014, 11:37 PM   #827
artwork's Avatar
Trader Rating: 54 (100%+)
You have to ream arms with an arm reamer and adjust the blocks until they do not bind. 2mm shims should work no problem
Once you get things adjusted and moving freely!
Also polishing the hinge pins makes a world of difference in the arms moving more free.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-30-2014, 11:42 PM   #828
Thanks,
What do you mean adjust the blocks?
Old 12-30-2014, 11:44 PM   #829
artwork's Avatar
Thanks,
Loosen the screws and hold the block away from the arm and retighten screws. It should provide some relief to the stress on the shims.
Old 12-30-2014, 11:45 PM   #830
Thanks again.
Old 12-31-2014, 08:16 AM   #831
Looking for some one to do a custom T4 2015 build. I travel a lot for work and do not have the time to do the initial build, plus I want it done professionally, graphite polished / CA'd and help pick and add components and tuned. I will pay for the build service. If interested send me a PM and how much you will charge. Thanks!
-DW
dreadwing is offline   Reply With Quote
Old 12-31-2014, 03:30 PM   #832
Chris Adams's Avatar
-DW
Pm sent
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 12-31-2014, 05:22 PM   #833
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
-DW
Originally Posted by Chris Adams View Post
Pm sent
Chris is the guy you want building your car!
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 12-31-2014, 11:19 PM   #834
Following up on the rear arms all sorted .
Old 01-01-2015, 12:25 AM   #835
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
But building the car is the best part!
- Ricky Bobby
Old 01-01-2015, 12:52 AM   #836
Greetings and Happy New Year.
I have just finished the assembly of T4 2015 and I have two questions:
1) When I assembled the shock shafts to the 4-hole 1.1mm pistons and inserted them into the alu shock body, I found that there is a lot of play. The pistons do not fit exactly into the shock body (the body is way bigger than the pistons) and at the final assembly the hole piston goes back and forth. Is this normal?
2) The upper bumper holder (part No 301216) has about 1-2mm gap from the alu front bulkheads. Is this my fault or is it disigned like this? In a serious crash I have a feeling that the chassis would brake. Has anybody had any issues with that?
Thank you in advanced.
Takvor is offline   Reply With Quote
Old 01-01-2015, 12:54 AM   #837
B00t13g's Avatar
^all normal.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-01-2015, 05:57 AM   #838
niznai's Avatar
You'd be surprised how much abuse the chassis can take with no problems.
None of the above is abnormal.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-05-2015, 10:00 AM   #839
danny250r's Avatar
Trader Rating: 38 (100%+)
anyone running avid titanium ball studs whats your input are they worth it ? thx
////BROKE A$$ RACING//// DREAM KILLR RACING ////ACTION RC2 R.I.P
NT1 //// INFERNO GT////Xray T4 15////Xray T3 VTA////TAMIYA M05////Losi SCTE 2.0////b5m
danny250r is offline   Reply With Quote
Old 01-05-2015, 10:07 AM   #840
artwork's Avatar
They are awesome...both of my cars have the full sets! They are super smooth, lightweight, and look awesome. Highly recommended!
SEO by vBSEO 3.5.0
