Like Tree1Likes
Old 12-27-2014, 09:01 PM   #811
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Originally Posted by metalnut View Post
If you're going to omit one of the two, omit the o-ring and use the gasket. But with a new o-ring (you can't really reuse them) and a used or new gasket, it should come together rather cleanly. You have to be careful and get it aligned the first time, but I've done it successfully many times and I'm not exactly coordinated. It helps to leave the o-ring on the bottom/filled part of the diff, and then cap it off from the top. You can use a bit of diff oil to seat the gasket in place as well, that way it doesn't fall off as you bring the top piece down.
I'm not sure why yours doesn't seem to fit properly, can you take a picture?
Here's a pic of the problem. The gasket isn't sitting properly and is therefore pushing up and disrupting the O-ring. I'm thinking the gasket needs trimming, otherwise I will omit one of the two. Any thoughts? (I don't have the proper front diff oil yet, so time isn't of the essence.)
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 12-27-2014, 09:33 PM   #812
LasagnaCat's Avatar
Trader Rating: 141 (100%+)
Send a message via AIM to LasagnaCat
As mentioned previously, skip the o-ring (or put a bit of diff fluid on the gasket to make it stick to the case.) We have five cars and I don't know how many gear diffs.. no o-rings, no leaks.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 12-27-2014, 11:05 PM   #813
Odin544's Avatar
Trader Rating: 93 (100%+)
Yup. Throw the o-ring away. I use a little AE green slime or equivalent on the gasket. Just a light coat on both sides. Helps seal things up and keeps the gasket from sticking to the case halves during disassembly. Plus it helps keep the gasket in place during assembly.
TriCitiesRC.com
Old 12-28-2014, 02:54 AM   #814
Salkin's Avatar
Does anyone know how much more weight the 301138 alu chassis is over the standard carbon fibre chassis?
I can see that Hagberg are mainly using the alu chassis and another Xray team driver at our club were testing the alu chassis with good results.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 12-28-2014, 03:31 AM   #815
Geberit's Avatar
Alu is about 40g heavier then carbon.
Geberit is offline   Reply With Quote
Old 12-28-2014, 05:15 AM   #816
Salkin's Avatar
Thanks!
Old 12-28-2014, 06:55 AM   #817
mschumi101's Avatar
Thanks for the help guys. I was thinking some green slime should help. So it looks like I'll be omitting the o-ring once my 2.5mil gravity rc oil shows up!
Orange Powered!
-Ted
Old 12-28-2014, 11:29 PM   #818
Trader Rating: 23 (100%+)
Hi guys, I am having some trouble achieving zero rebound with the shocks. I am using RSD shock internals.
After i 'bleed' the shock a number of times, the oil doesn't want to bleed out anymore and I am stuck with an almost 100% rebound on one of the shocks. The 3 other shocks I have managed to achieve about 0-10% rebound.
Anybody got any tips?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 12-29-2014, 12:58 AM   #819
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
I'm using the RSD pistons but I prefer the Xray bladders. With the pre-drilled hole in the plastic portion of the shock cap, 0% rebound should be pretty easy. Check to make sure the hole isn't plugged (or missing?) in the shock that isn't building right.
- Ricky Bobby
Old 12-29-2014, 02:59 AM   #820
Fill the shock and get the air out. Place the bladder on the shock, and gently work it in with a 5.5mm nut driver, to push excess oil out. Then place the plastic cap on the bladder to hold it in place. Then screw on the aluminum piece. If that doesn't give you 0-10% rebound, then something is weird with your shocks. Maybe one cap doesn't have a hole? Or it's plugged as metalnut mentioned. I'm not sure if they're molded that way or drilled at the factory.
-Mike
Old 12-29-2014, 03:27 AM   #821
daleburr's Avatar
You need to be a bottom bleeder
I assemble mine with the rod all the way out giving full rebound. Fit the bladder and install the cap, without doing any bleeding. Then turn the shock upside down, unscrew the bottom cap and push the shock rod to one side. All the extra pressure will bleed out, leaving a perfect zero-rebound shock with no air.
Team Xray
Old 12-29-2014, 07:35 AM   #822
niznai's Avatar
That's probably the best way to build shocks. Xray should have kept the bottom bleeding feature they had in the past (and so should everybody else).
I work the bladder on and the take the top plastic (not the whole cap) fit it on the bladder in its final resting position, hold it there with light pressure and push the piston all the way in allowing the excess oil to bleed out. Keeping the piston all the way in, I place the cap ring on the plastic and screw it in taking care to maintain pressure on the plastic and making sure it doesn't move around on the bladder. That's the only other way (more convoluted and finicky) to ensure consistent and reproduceable shock builds.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is online now   Reply With Quote
Old 12-29-2014, 08:01 AM   #823
artwork's Avatar
Trader Rating: 60 (100%+)
I think there is a pretty good video about how to build Xray shocks with zero rebound.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 12-29-2014, 01:53 PM   #824
grapejuice's Avatar
Trader Rating: 133 (100%+)
Really good method here for bleeding xray shocks, works very well for me:
https://www.youtube.com/watch?v=DhEDwZm8omM
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 12-29-2014, 03:04 PM   #825
This is perfect, worked like a charm! Thanks!
