Xray t4'15
#797
This one should work too, though you'll have to trim it yourself: http://www.discountrcstore.com/epic1...mor_s/1328.htm
The Epic 1 chassis protector is the best on the market.
You can peel it and re-stick 100 times and it will not wear through on asphalt.
#798
So I am building a front gear diff for the car (my first X-ray gear diff, since I bought my car used) and I am having a tough time getting the paper gasket to seat properly. It doesn't sit in the case entirely and disrupts the black ring. Are you guys omitting the paper gasket? Or modifying it slightly to sit in the channel? Thanks in advance.
#799
I'm not sure why yours doesn't seem to fit properly, can you take a picture?
#800
Are You sure you have the two halves lined up?
On the bottom half of the diff (the bit you put the planet gears in) there is a little stud this needs to line up and go between the two lines on the top half of the diff.
#801
Could someone tell me how to read the "wheelbase" section in the setup sheets (top right section):
http://forum.teamxray.com/xform/inde...&setup=t4_2015
#802
so if it is the 0 ticked it means no shims in front which means both shims are at the rear of the arm.
If 1 is ticked the it means 1 shim in front and one shim at the rear
if both 1's are ticked the it means both shims in front, no shims at the rear.
shims are 1mm.
#803
the boxes underneath 0 1 1 refer to the number of shims in front of the suspension arm.
shims are 1mm.
shims are 1mm.
#805
Spur Gear Screw Hole Pattern
I'm building my first X-ray car, and I'm attaching the spur gear. I was going to use a different tooth spur than what came with the kit, and all of my spurs that I have do not align with the screw holes on the spur gear adapter. I thought spur gears were universal in terms of screw hole patterns. Must one use an Xray spur?
#806
Nah. If you have any serious spur with a 12 hole pattern, should fit. The more serious problem is thickness and offset. There's a few aftermarket companies that make spurs for (or fit) xray
#808
#809
Hi guys, I just got a new set of TRF DCJ's (42216) + Smokem spool outdrives. But the 42216 set only has 2 ball bearings, and the DCJ's don't seem to be able to fit through the stock ball bearings. Even if I put both ball bearings from the DCJ kit onto one steering block, the hex adaptor thing seems to rub against the steering block pretty seriously? Could anyone tell me how they got around this?
#810
The hex also shouldn't be rubbing against the steering block. When you put the retaining pin through the DCJ and fit the hex over that, the hex should be sitting up against the outside bearing. There may even be a bit of play, I believe I have my shimmed with 0.1mm shims between the DCJ and the inside bearing.
