Like Tree1Likes
Old 12-18-2014, 08:57 PM   #781
R/C Tech Elite Subscriber
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Any particular reason you converted to normal suspension instead of just keeping ars in a neutral setting, if that's even possible?
Originally Posted by pcar951 View Post
I ran ARS for a month or so on carpet, never found a setup that felt like an advantage, lap times were the same (I need to do more testing). I've since switched back to the standard rear suspension. FWIW, I run 17.5 and mod and never broke anything with the ARS system.
lagcisco is offline   Reply With Quote
Old 12-18-2014, 09:15 PM   #782
B00t13g's Avatar
I don't glue my chassis, but I do sand and smooth the edges.
The hudy/ xray ecs are good, but they will bend or break in a hard hit just like everything else. The rsd ecs shafts are a good option as well and are much more budget friendly. I've run both and neither fell apart or came undone.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-19-2014, 07:43 AM   #783
Trader Rating: 24 (100%+)
Anyone used or seen these?
Justin Cornett
RC America / XRAY / HUDY / KoPropo / Team EA Motorsports / AVID RC / RSD / ReflexRacing.net
gocoogs is offline   Reply With Quote
Old 12-19-2014, 01:37 PM   #784
rangerjkb's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to rangerjkb
For the price and durability, I prefer the Roche, Tamiya, or RSD DCJ's. The retaining pin rings seem to be better than other options for holding the pins in while providing least amound of joint binding. The spring steel versions tend to bend less and last longer.
Very nice outdrives, first time seeing them
Using the "ARS" version rear suspension with no durability issues, but alot of testing still needed to see if they will actually provide any performance gain over the stock A-Arm configuration.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 12-20-2014, 05:33 AM   #785
Do the Tamiya DCJs fit without any mods?
niemand is offline   Reply With Quote
Old 12-20-2014, 05:34 AM   #786
Quick question to all the Savöx users here:
Which letter insert do I need for the Xray servo saver?
Old 12-20-2014, 06:40 AM   #787
metalnut's Avatar
Trader Rating: 36 (100%+)
Futaba, so F
- Ricky Bobby
Old 12-20-2014, 06:47 AM   #788
Originally Posted by metalnut View Post
Futaba, so F
Old 12-20-2014, 11:30 AM   #789
Search button.
-Mike
Old 12-20-2014, 05:01 PM   #790
Looks interesting, are the pins replaceable.
frozenpod is offline   Reply With Quote
Old 12-21-2014, 08:06 AM   #791
rangerjkb's Avatar
Not that I am aware of, had to use aftermarket outdrives (Smokem Racing).
Jason Burks
Old 12-22-2014, 08:56 PM   #792
SpidarX's Avatar
Does anyone make a chassis protective sticker for the T4 '15?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 12-23-2014, 01:30 AM   #793
B00t13g's Avatar
http://www.rccarshop.co.uk/index.php...-2-sheets.html
Mackenzie Meyercord
Old 12-24-2014, 12:21 AM   #794
metalnut's Avatar
This one should work too, though you'll have to trim it yourself: http://www.discountrcstore.com/epic1...mor_s/1328.htm
- Ricky Bobby
Old 12-24-2014, 04:03 AM   #795
Salkin's Avatar
Why do you use a protective sticker?
On carpets the chassis doesn't get scratched that much and on asphalt the hard surface will tear through the sticker anyway.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
