Like Tree1Likes
Old 12-17-2014, 12:12 PM   #766
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Originally Posted by grippgoat View Post
I don't think breaking is so much the issue, as falling apart.
-Mike
I wasn't a fan of the Xray ECS as my would fall apart (set screw would back out), but I realized I was using shitty loctite. Ever since I switched to this stuff I've had 0 issues with any of my loctite screws coming out, including the ECS set screws: http://www.amazon.com/gp/product/B000HBM5TQ/
- Ricky Bobby
Old 12-17-2014, 11:31 PM   #767
niznai's Avatar
Originally Posted by millbank View Post
I ran the Xray 2mm Ecs's last year outside in mod and never had an issue. Not sure what people are doing to break them. I hit quite a lot of stuff but they are still going.
Poor assembly is my guess.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-18-2014, 12:01 AM   #768
Salkin's Avatar
The ECS's has in the two joints a short and a slightly longer pin that must be used in the correct place. Guess if someone assembled the ECS's with the pins in the wrong place (I actually did at first), you could break the ECS more easily, as the short pin in the wrong place would be proned to pop out or tear the joint.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 12-18-2014, 12:18 AM   #769
niznai's Avatar
That would be one way to screw up.
Not doing up the grub screws properly, or using crap loctite, or greasing the threads before using loctite are a few more.
Team Greasy Weasel
Old 12-18-2014, 01:16 AM   #770
Or one of the G clip options and done.
-Mike
Old 12-18-2014, 01:21 AM   #771
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
they never lasted more than a season for me
The TRF and even RSD ones have longer lifespan.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 12-18-2014, 04:11 AM   #772
Skiddins's Avatar
Don't bother with tyhe small grub screws at all, just use heatshrink around the 'elbow' joint and they should last until you rebuild them.
I have bent ECS dog bones in big crashes, but never snapped anything.
Eventually the OEM items wore out and as they are expensive to replace I started using RSD items.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-18-2014, 09:16 AM   #773
artwork's Avatar
Trader Rating: 56 (100%+)
I think there a video about building Xray ECSs somewhere
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-18-2014, 12:59 PM   #774
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Anyone running normal suspension in the rear?
Should I be concerned about durability on the ARS?
I want to buy some spares but am considering getting non-ARS replacement parts for the rear instead.
lagcisco is offline   Reply With Quote
Old 12-18-2014, 01:16 PM   #775
SpidarX's Avatar
Is everyone gluing the edges of their chassis? How important is this?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 12-18-2014, 01:18 PM   #776
locked's Avatar
With the old XRAY ECS', the pins would sometimes break. Now they made the pins bigger, the round bit at the end of the shaft that the barrel goes in is weaker and that shears right off. I've had much better luck with the Arrowmax DCJs, but you just have to remember to turn the retaining clips around on one, making a left and a right, so the open end of the clip won't catch on anything when it rotates forward.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-18-2014, 01:23 PM   #777
cmunro's Avatar
Trader Rating: 12 (100%+)
so far the rsd are my favorite ,cost effective and long lasting
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 12-18-2014, 01:31 PM   #778
Odin544's Avatar
Trader Rating: 93 (100%+)
I glue mine. Its pretty cheap insurance to help protect the chassis.
TriCitiesRC.com
Old 12-18-2014, 01:34 PM   #779
locked's Avatar
I didn't do this at all for my first few cars and I never had any issues. My latest car I did a really nice job of sanding and sealing all the edges, but last Sunday I managed to delaminate my chassis for the first time, I'm fairly certain it is because the upper bumper brace doesn't quite fit snugly enough against the bulkheads, and the plastic dents, so if you don't do damage on the first couple of solid hits, you probably will eventually.
I don't really think CAing the edges makes much difference, but it does look good if you do a nice job of it
Dave Locke
Old 12-18-2014, 07:13 PM   #780
pcar951's Avatar
Trader Rating: 19 (100%+)
I ran ARS for a month or so on carpet, never found a setup that felt like an advantage, lap times were the same (I need to do more testing). I've since switched back to the standard rear suspension. FWIW, I run 17.5 and mod and never broke anything with the ARS system.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
