Like Tree1Likes
Old 11-08-2014, 08:12 AM   #631
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Originally Posted by grippgoat View Post
Yeah, I didn't mean spares or taking shocks apart. Just trying your old shocks if you're not running the car.
-Mike
Oh, yeah, I can bring that. It's "in pieces" until I get my RSD chassis and the suspension blocks.
- Ricky Bobby
Old 11-08-2014, 10:39 PM   #632
SpidarX's Avatar
I'll be getting the new T4 '15 in the near future. This will be my first X-ray car. What spares or options (e.g., spring sets, etc) should I consider along with the new car?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 11-08-2014, 11:27 PM   #633
metalnut's Avatar
The car comes with 2.5 springs front and back. If you have the cash, buying the full set of springs isn't a bad idea, but you have to buy them two at a time. I would honestly see how the 2.5 all around feels before you spend money.
If you like spools then you'll be golden, but if you like front gear diffs prepare to spend some cash for one (I think it's like $60).
You'll probably also want some DCJs up front, there are a number of options. The Xray ones are expensive as hell ($50 for one... yes, just one) and you have to make sure you use high quality loctite or they fall apart. RSD DCJs are very nice and much more economical (and use rings instead of set screws, yey!), as are "Version 2" of the Spec-R (see discussion on the previous pages).
That's basically it. The car is solid. Any other options will depend on what class you want to run and on what track surface.
- Ricky Bobby
Old 11-09-2014, 02:43 AM   #634
I'd start with just DCJs, and maybe the top deck post if you're on carpet. I wouldn't splurge on springs right away.
-Mike
Old 11-09-2014, 07:09 AM   #635
niznai's Avatar
I don't think you're going to need anything provided you can drive.
Drive it first and the car will tell you what you need.
Spurs and pinions are a must have, but I assume you might have some of these if you've had cars before. If not, just ask about at your club what sort of gearing you need and figure out the range of pinions/spurs you might want.
If you're thinking of ordering on the web and want to have everything in one order, again, take a trip to your local track and ask around.
Asking here you might end up buying stuff you'll never need.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-09-2014, 12:55 PM   #636
SpidarX's Avatar
Thanks for the replies, they were helpful.
Maclan Racing
Old 11-10-2014, 12:34 AM   #637
Smokem Racing's Avatar
Hi everyone. Sorry for the long wait on the Gear Diff Cups for the Tamiya DCJ's. Production has just been completed and they are undergoing final inspection. They will be up on our website in the next few days.
Don't beat them. SMOKEM...
shop.smokem-racing.com
facebook.com/smokemracing
Smokem Racing is offline   Reply With Quote
Old 11-10-2014, 12:45 AM   #638
metalnut's Avatar
Awesome It's good to have options.
- Ricky Bobby
Old 11-12-2014, 05:42 AM   #639
Originally Posted by Troy Carter View Post
I've had a couple sets of the Spec-R v2's that were phenomenal for the cost. They lasted forever and were a great price.
HOWEVER, that has changed with the new P8 version that has replaced them. The first set I got the axles snapped, both of them within 4 packs. The first snapped when I tried to tighten the wheel nut before my second run. The second snapped when I had a light board tap, nothing that I would have expected to snap an axle.
I would strongly suggest avoiding the new P8 version of the Spec-R shafts.
I've had the same experience with 2 sets of the new P8's both snapping. I also have had the two sets of the V2 which lasted a very long time. I run 4.5T mod and wasn't gonna waste anymore time so I chucked out $100 for the Xray 2mm ECS. I just built my 2nd T4'15 which I originally bought for spares only but no one has the single chassis for sale in the US. I used the little axle capture with rings from the broken P8's on an old set of Xray 2mm pin ECS's in this new car and they work fine.
Xray T4 2015 /Team Orion R10.1/Scorpion RS-3420 4.5T/RSxone10/Sanwa M12:rx-471
Xray T4 2014 /LRP Flow Worksteam/LRP X20 4.5T/RSxone10/Sanwa M12:rx-472
Xray XB4 /LRP Flow/LRP X20 6.5T/Savox 1251MG/Sanwa M12:rx-471
Durango DEX410v4 /Tekin RSX/Tekin RL 6.5/Savox 1251MG /Sanwa M12:rx-471
rafyel is offline   Reply With Quote
Old 11-12-2014, 02:43 PM   #640
Spider x, the spur that it comes with is more of a mod class spur....so you'll need to replace that as you're building preferably. I switched to the 64pitch spur.
Tltype1 is offline   Reply With Quote
Old 11-12-2014, 10:15 PM   #641
veecee's Avatar
Trader Rating: 34 (100%+)
They're listed on the Smokem website now http://shop.smokem-racing.com/Smokem...CJs_p_199.html
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 11-12-2014, 11:28 PM   #642
metalnut's Avatar
Sweet, got a set coming, thanks!
- Ricky Bobby
Old 11-13-2014, 11:36 PM   #643
syndr0me's Avatar
Trader Rating: 32 (100%+)
It will be interesting to see if Tamiya's plastic blades would hold up better in the T4. Even though the DCJ's are great, I was replacing blades every 3 runs in mod on the 418.
syndr0me is offline   Reply With Quote
Old 11-14-2014, 12:30 AM   #644
vabroom's Avatar
I liked the V2s once I had the retaining clips on in the correct direction. They held up just fine, but then again I was using them in a 25.5 class so not that much power flowing through them. I have no experience with the new P8 version, but the above experience sounds bad.
The RSD DCJs are very good. Fit and finish is great, just keep them lubricated as they can develop some surface rust (at least it looks like rust). Very little play and come together (and stay together) without a problem, those would be my recommendation.
Metalnut, how did you install the retaining clips? If possible pics. I would think this is for any DCJs.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 11-14-2014, 12:58 AM   #645
metalnut's Avatar
I'm not sure I follow your question... what do you mean how did I install them? Carefully Also, with the hook end facing the direction of rotation.
- Ricky Bobby
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
