Old 11-03-2014, 10:11 PM   #601
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Originally Posted by Odin544 View Post
Will the 51mm ecs's from Roche or RSD work in the rear without binding? Or do I need to get a set of 50mm?
With the standard rear end, they should work. I have not tried with the ARS, but it could be a tight fit since it is a bit narrower.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-04-2014, 02:50 AM   #602
Raymann's Avatar
Originally Posted by metalnut View Post
That's kinda funny, actually
It does sound like something happened to the shock parts bag QA, I'm going to assume that they were rushing to get the 2015s out the door. Anyone want to start a parts exchange? I'll have an extra cap on wednesday I can mail to whomever is missing one
lol
RAYMOND JW,
###XRAY T4 2013### IN AUSTRALIA...
@ IMCC (Illawarra model car club) http://www.imcc.org.au/
Raymann is offline   Reply With Quote
Old 11-04-2014, 11:43 PM   #603
So, how are y'all liking the '15 vs the '14? Are you find performance improvements, or is it mostly just quality of life?
-Mike
Old 11-05-2014, 01:08 AM   #604
fullout's Avatar
Send a message via MSN to fullout
-Mike
Coming from a 13 it is a huge improvement. It is way more forgiving and consistent.
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 11-05-2014, 03:17 AM   #605
Trader Rating: 23 (100%+)
Hmm would like to know if the ARS has enough toe change to really warrant the use of ECS's... let us know what it feels like!
Yokomo BD7 15 | Team SILVERBACK | LRP | FUTABA
Zhangesh is offline   Reply With Quote
Old 11-07-2014, 12:06 AM   #606
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Quick question... I know that to run the Tamiya DCJs with an Xray spool, you need tighter cups such as the Smokem ones. But is it possible to run the Tamiya DCJs with an Xray gear diff? Does someone make gear diff cups of similar smaller/tighter design?
- Ricky Bobby
Old 11-07-2014, 01:36 AM   #607
daleburr's Avatar
Get yourself a set of the Roche T4 DCJs and problem solved. They'll last forever (mine still look brand new after a season outdoors) and don't require any bodgery.
http://www.roche.hk/shopping/index.p...product_id=804
Team Xray
daleburr is online now   Reply With Quote
Old 11-07-2014, 03:31 AM   #608
niznai's Avatar
You have more options than that.
You can use a Tamiya spool shaft and outdrives and bolt on an Xray 38 tooth pulley from the old ball diffs (the bodgery here is to machine the locating boss and to drill the holes in the right place which is not that hard once the boss is machined).
For the diff, you can try to find Tamiya outdrives that'll fit the Xray gear diff. I think I have looked at this in the past, but can't remember what I did.
But why would you want Tamiya DCJ anyway?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-07-2014, 06:00 AM   #609
Or you can use this:
https://smokem-racing.3dcartstores.c...DCJs_p_20.html
But why?
*LAF Painting*
february is offline   Reply With Quote
Old 11-07-2014, 06:07 AM   #610
Trader Rating: 13 (100%+)
Originally Posted by february View Post
He's looking for outdrives for a diff. Tamyia's DCJ's are the best.
I did see the Smokem guy say he was working on cups for the diff, not sure what happened with that.
Sean B. is offline   Reply With Quote
Old 11-07-2014, 06:33 AM   #611
oladele's Avatar
Xray ECS's come in 50mm and 52mm what is the difference in running one over the other?
oladele is offline   Reply With Quote
Old 11-07-2014, 09:27 AM   #612
metalnut's Avatar
For those asking why... just to figure out what's available. I have and have tried Xray, RSD and Spec-R DCJs on my T4. I also have a set of Tamiya DCJs already and there was a discussion about fitting them a while ago. I have the Smokem cups for a spool, but the gear diff situation was my question.
And yes, the general opinion seems to be that Tamiya DCJs are the best quality out of the ones I've mentioned, though I'm really liking my RSD ones.
- Ricky Bobby
Old 11-07-2014, 11:19 AM   #613
Is the pin on the tamiya DCJs larger or smaller than xray? If larger, could you just drill out some blades? I can't remember if I have a pair of the xray steel diff outdrives in my parts bag, and whether they use blades or not.
-Mike
Old 11-07-2014, 12:11 PM   #614
niznai's Avatar
Marginally larger but it won't help because the outdrive ID (and the driveshaft dog bone end) on Xray is 1mm larger.
Xray has made an Aluminium spool with a smaller ID outdrive (it was in fact a one piece affair) for the T1 but you'd be hard pressed to find one.
Team Greasy Weasel
Old 11-07-2014, 12:18 PM   #615
syndr0me's Avatar
Trader Rating: 32 (100%+)
The c-hubs on the '15 make me think there's something new coming from Xray as far as ECS go. The existing ones are really pretty mediocre compared to the other options out there. The quality is below Xray's standards honestly.
The Awesomatix has the best I've used in terms of maintenance. Tamiya is second for me.
syndr0me is offline   Reply With Quote
SEO by vBSEO 3.5.0
