Like Tree1Likes
Old 10-28-2014, 03:43 PM   #556
R/C Tech Elite Subscriber
Thank you guys soooo much! Ironically I just blew a rev/trin 7150/100c the other day....soldered wrong wires....pop! Left my esc in one piece though. That was the more expensive piece...lol
Tltype1 is offline   Reply With Quote
Old 10-28-2014, 03:48 PM   #557
Has anyone tried heavier diff fluid in the rear? I have the ars system, plus front diff with 1,000,000wt. It seems fishy in the back?
Old 10-28-2014, 04:57 PM   #558
Trader Rating: 57 (100%+)
Originally Posted by samnelso View Post
25g alone in those tires compared to what most of us yanks run.
Sorex 32's with revlite wheels and yellow insert - 123g
Sorex 28's with revlite wheels and yellow insert - 122g
Jaco blue (snowbirds batch) - 119g
Sweep 32 - 121g
Did I get the wrong kind of sorex? They come from amain in schumacher packaging.
PROMODVETTE is offline   Reply With Quote
Old 10-28-2014, 05:52 PM   #559
imprsme's Avatar
Trader Rating: 72 (99%+)
Not sure why yours are so close.
Just weighed Sorex on Revlites, Gravity C's and Jaco blues Not even close..lol
Sorex 28 on revlite wheels blue inserts- 94g's
Gravity "C" compunds-128g's
Jaco Blues-114g's
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 10-28-2014, 07:02 PM   #560
Odin544's Avatar
Trader Rating: 93 (100%+)
Xray t4'15
TriCitiesRC.com
Old 10-28-2014, 07:12 PM   #561
Trader Rating: 23 (100%+)
what cst oil are you running in the rear?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-28-2014, 09:51 PM   #562
Dusttt's Avatar
Trader Rating: 119 (100%+)
probably a stupid question but when running a front diff in these cars do you have to go to 50mm drive shafts or will 52 work?
"Whiskey Tango Foxtrot"
Dusttt is online now   Reply With Quote
Old 10-28-2014, 09:55 PM   #563
vabroom's Avatar
This question. ^^^^^
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 10-28-2014, 10:15 PM   #564
Odin544's Avatar
Not sure if it's required to run 50's but that's all I ever see people run on carpet.
TriCitiesRC.com
Old 10-28-2014, 10:26 PM   #565
pcar951's Avatar
Trader Rating: 19 (100%+)
I run 52mm ecs drive shafts with a diff in front no problem.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 10-28-2014, 10:32 PM   #566
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
+1, was fine in the '14. Haven't tried yet in the '15 but I don't expect it to be any different.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-29-2014, 12:37 AM   #567
Barry_Hughes's Avatar
Originally Posted by millbank View Post
I've found the easiest way to adjust on the inner stand is to remove the bottom screw from the chassis then add or remove shims with the end of the arm in the open. Easier than trying to negociate the diff,belt and top deck.
Think he actually means to get the inner link lower. At present there seems to be a lot of scope for adjusting the ARS to get less toe in. But very little to gain toe in.
By replacing the inner post supplied in the kit by an m3 x 8 (or 10 or 12) screw and a threaded ball (like the one used to hold the shocks) you could in theory run with a 1mm spacer sitting on the chassis and get mega change of positive toe in. but you could run lower than 6mm height on the inner link which is the lowest with the supplied inner post.
I know one racer at the weekend had milled 2mm of the inner post to get more change in positive toe
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 10-29-2014, 04:37 AM   #568
Default X-Ray T4 2015
Hey guys.
I consider building an X-Ray T4 2015 for mod racing. I haven't had a 1/10 Touring car before. I've only driven 1/8 GT8 onroad (Ofna X3 GT and Kyosho Inferno GT2).
The build i'm considering is this:
Car : X-Ray T4 2015
Esc/motor: Tekin RSX Gen2 / Redline 4,5t or 5,5t
or Orca VRITRA VXX V3.3 / ORCA RX3 4,5t
Servo: Savox SC-1251MG - Low Profile, High Speed
Batteries: SMC Race Formula 7.4V, 7200 mah 70C
or Orca Infinite Ultra 7.4V, 7500mah 90C
What choices would be better for a modified tourer, and does this look like a descent setup for a competition car
About getting same as other racers at track, and availability of parts etc doesnt matter much. I buy parts online, and I just want to build a very good racer
Thank you for suggestions
Frank
Snikopat is offline   Reply With Quote
Old 10-29-2014, 02:05 PM   #569
I'm running 2000
Old 10-29-2014, 02:29 PM   #570
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Xray t4'15
I hope you realise we already have a thread for this car (SEE ABOVE) so really there's no need to post here
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
