Like Tree1Likes
Old 10-23-2014, 08:58 AM   #526
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by locked View Post
This thread needs more people discussing their ARS. Does your ARS develop slop over time?
EA, did you check out your ARS last night? Inquiring minds would like the measurements of your ARS.
Where's Alex Hagberg? We need him to tell us about his ARS.
Of course I'm joking around, but in all seriousness, I would love to hear what settings people have tried on various surfaces and the results.
You are really into this ARS thing aren't you? It's okay I'm an ARS man.
I started the teardown of my '14 last night. Tonight I start on the '15.
TriCitiesRC.com
Old 10-23-2014, 09:11 AM   #527
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm building my '15 without ARS to start. I'll add it on once I'm comfortable with how the car feels with a normal rear end. Single variable. All changes in isolation.
syndr0me is offline   Reply With Quote
Old 10-23-2014, 09:22 AM   #528
Odin544's Avatar
Are you going to the TZGP?
TriCitiesRC.com
Old 10-23-2014, 12:59 PM   #529
Clint161's Avatar
Set-up sheets are now on Xray website.
Clint161 is offline   Reply With Quote
Old 10-23-2014, 01:07 PM   #530
syndr0me's Avatar
Nah, taking a break from race travel. Spending a week in Vegas to fail over and over is about all the fun I can handle right now.
Old 10-25-2014, 09:42 AM   #531
Does anybody knows the difference in lenght of the swaybars from the T4 14 compared to the T4 15.
If anybody has both the ones from the new and the previous and can post a picture of the lying next to each other, then I would be greatful.
Shock Tower is offline   Reply With Quote
Old 10-25-2014, 10:08 AM   #532
erchn's Avatar
I made this a while ago. Hope it helps.
https://www.dropbox.com/s/zpgccdjz34...r_bar.png?dl=0
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 10-25-2014, 11:50 AM   #533
Nice, just what I needed. I am trying to fit the T4 15 swaybar links attached to the wishbones, to my T4 14.
But think the T4 14 swaybars are about 4-5mm to long to get it to work.
Maybe I will cut them, and se if it works.
Anyone has done this before me ?
Old 10-25-2014, 12:06 PM   #534
erchn's Avatar
There are definitely people that I've done it with other manufacturers bar end links, so it should work just fine.
Old 10-25-2014, 07:26 PM   #535
Odin544's Avatar
Buddy of mine used the ARC ends and just cut his sway bars down a little last year. Worked out fine.
TriCitiesRC.com
Old 10-26-2014, 02:11 AM   #536
millbank's Avatar
ok... ARS
I will probably be laughed at for this but hey ho.
I found that there was not enough change in toe to make a big difference on carpet due to it being a relatively flat surface with no bumps to cope with. this means that the suspension only changes toe in the corners. i've modified my ars to give a maximum of 2 deg change under load. with a setting of 2 deg inboard toe and 0 outboard when cornering i get about 3-3.5 deg on the side under load. making the car super sharp and less drag on the straight. i'm only just starting to look into this but the rear was very stable unless you made very severe steering inputs. i'm a smooth driver and feed the steering not sharp stabs. i put in the fastest lap of the night but only 0.01 quicker than another kid at club running the 15. with that said he is normally 0.2 quicker than me on a single hot lap. i am going to install the standard rear for next friday as we run the same track 2 weeks in a row. it will be good to see the difference if there is any
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 10-26-2014, 02:20 AM   #537
millbank's Avatar
didn't make the first bit clear...
because there are no significant bumps on a carpet track i believe that allows you to run more ars toe without the car being unstable when hitting bumps
Old 10-26-2014, 10:38 AM   #538
Skiddins's Avatar
Originally Posted by millbank View Post
ok... ARS
What settings did you have on the ARE to get that big change during cornering?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-26-2014, 11:13 AM   #539
millbank's Avatar
I switched the steering knuckle ball stud to be on top of the steering knuckle not underneath and changed the other end to a 10mm ball stud and put 6mm of shims on the mounting post. I now have loads of adjustment
Old 10-26-2014, 12:23 PM   #540
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
millbank, Thanks for sharing ARS trials as I'm sure many of us are eager to get it to work for intended added performance gains. Planning to build the ARS configuaration also for the winter carpet season in hopes to find positive results.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
