Like Tree1Likes
Old 11-21-2016, 10:37 AM   #1801
Trader Rating: 37 (100%+)
Anyone have an aluminum chassis for the 2015?
Mi4cxl likes this.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-22-2016, 07:01 AM   #1802
daleburr's Avatar
The '16 and '17 chassis will fit without needing any other parts or mods.
RCDisco are clearing the '16 chassis out at 40% off:
http://www.rcdisco.com/part-info.php?partNo=XR301140
Team Xray
Old 11-22-2016, 09:46 AM   #1803
RobS's Avatar
Are you sure? The 15 and 16 chassis are interchangeable but with everything centralized on the 17 I don't think it would work.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 11-22-2016, 09:49 AM   #1804
Does anyone know what is different?
thatrccarguy is offline   Reply With Quote
Old 11-22-2016, 10:02 AM   #1805
So the 2016 chassis fits for sure?
Old 11-22-2016, 11:13 AM   #1806
Trader Rating: 16 (100%+)
Send a message via ICQ to Solara Send a message via AIM to Solara
Does anyone know the 2015/2016 aluminum chassis fits T4 2014? I know there is some different but I am not sure where....someone mentioned it is only the SERVO MOUNT, 2015 use 3 holes and 2014 use 2 holes...if that is the case I think i can buy the chassis and 2015 servo mount and get it updated....
But if the whole bulkheads of 2014 are totally different (wider, longer shorter...etc) then that is not worth it.
Thank you
Solara is offline   Reply With Quote
Old 11-23-2016, 02:05 AM   #1807
daleburr's Avatar
Yes I have a '17 Alu chassis on my old '15, zero extra parts needed. Only thing you might want to do is dremel the top-deck around the pinion, as there's no hole in the chassis to get to it on the '17.
Servo has been centralised but that works fine with the old servo mount. Motor mount hasn't moved.
One thing to be aware of is that they've moved the RF suspension blocks outwards slightly on the '17, so you get about 0.5deg less toe than on your old chassis. Easily corrected with different inserts.
And the steering posts moved backwards, so add a 1mm ackerman spacer to keep the ackerman similar to before.
Team Xray
Old 11-23-2016, 02:06 AM   #1808
daleburr's Avatar
Thank you
The expensive stuff (bulkheads and suspension mounts) are all the same. You'll need a new servo mount and motor mount.
Team Xray
Old 11-23-2016, 04:37 AM   #1809
Skiddins's Avatar
Is that not by accident?
It certainly wasn't mentioned in the literature for the car when released.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-23-2016, 08:37 AM   #1810
daleburr's Avatar
Maybe. Even OJ wasn't aware they'd done it until I told him!
Not sure if the '17 carbon chassis is the same (haven't got a '17 car yet - just a '17 alu chassis), but will definitely check as I don't like 2.5deg toe for club racing.
Team Xray
Old 11-23-2016, 10:10 AM   #1811
so how much of toe you recommend Dale? I am currently using 3 degrees,what do you think?
pimp it is offline   Reply With Quote
Old 11-23-2016, 03:51 PM   #1812
daleburr's Avatar
Depends on the traction available. 3deg for low/med traction (and for small start/stop tracks).
2.5deg once traction starts coming up at faster circuits where you need the corner speed.
Old 11-23-2016, 11:00 PM   #1813
thanks Dale
Old 02-17-2017, 02:17 AM   #1814
Default Lower deck (main chassis)
Hi, racers! Need some advise.
Can i install main carbon chassis (lower deck) from t4-2106 to my t4-2015?
D.Nikolaev is offline   Reply With Quote
Old 02-17-2017, 02:49 AM   #1815
Ahahahaaaaa, i'm sorry! I had to scroll a few posts up! Good luck, peppers!
