Like Tree1Likes
Old 07-20-2016, 02:29 PM   #1786
Trader Rating: 20 (100%+)
Start with the aluminum chassis and work from there. The Carbon arms, arm stiffeners, etc are all very minor things that just are not requirements to get run extremely well at the club level.
I would get the hard bumper to protect the front of the car better. And maybe a step or two of various sway bars and springs so that you can tune the car to your driving style.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 07-26-2016, 08:45 PM   #1787
Slapjack's Avatar
Trader Rating: 19 (100%+)
That is probably what I'll do but I get addicted to buying upgrades as I'm sure a lot of people do. My last t4 had the option while belts and alum steering arms. So I will probably probably pick those up along with the hard bumper. The other thing I saw for high traction tracks was the radtec floating steering rack. It looks cool but I sort of remember a debate on here awhile back about why people didn't like them. Is there a reason you wouldn't want to run that?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is online now   Reply With Quote
Old 07-27-2016, 08:38 AM   #1788
Slapjack's Avatar
Originally Posted by vabroom View Post
Don't know if it still applies to today's material but some manufacturers sometime back thought opposite materials (metal against plastic} have less friction and wear than similar materials (plastic against plastic).
Yea that is what I noticed is that they had composite shims on the aluminum parts and aluminum shims on the composite parts. Thanks, I knew there was some reason they wanted to do that. I just used all aluminum shims but just was curious why they did that.
Old 07-27-2016, 08:07 PM   #1789
Slapjack's Avatar
I am trying to decide between a Savox 2261 and spektrum 6270... They both have similar specs but the spektrum is 6.0v 7.4 or 8.4 I believe and the Savox is 4.8 or 6.0. The Savox at 6.0v is like 138oz/.07 approx and the spektrum at 7.4 is approx 150oz/.06 and a little higher torque and faster speed at 8.4v. Is there any reason it's better to have the higher voltage one? Or doesn't it matter. I like the Savox servos and the 2261 looks cool too and matches the t4 orange. But I have also heard good things about the spektrum servos too
Old 07-28-2016, 06:08 AM   #1790
This will change the car. I'm not sure if that's good or bad in your situation but I would not put this on my list of must have items.
Old 07-29-2016, 06:51 AM   #1791
Slapjack's Avatar
I am installing the '16 chasis on my '15. will my '15 upper deck work still or do I need a new deck? Wasn't sure if the holes are still going to line up. I assume they will but Just wondered if anyone knew for sure so I can get it ordered if I need to.
Old 07-29-2016, 07:05 AM   #1792
RobS's Avatar
It will work.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 07-29-2016, 08:38 AM   #1793
tbrymer's Avatar
Yep, everything should work just fine. I think there are a few more holes on the 2016 chassis, but all the 2015 holes are still there.
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 07-29-2016, 09:53 AM   #1794
vabroom's Avatar
It should work. Discount RC Store has a T4 16 upgrade:
http://www.discountrcstore.com/XRAY-...t415update.htm
Unless you race on a very high grip track you don't need the ARS suspension mounts. The topdeck is nice to have if you use the center topdeck mount. The motor mount plate is use for rear flex.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 07-30-2016, 07:24 AM   #1795
crusty's Avatar
What do most people find using the front steering post does? Its not often used in setups for some reason
crusty is offline   Reply With Quote
Old 07-30-2016, 07:51 AM   #1796
I think that varies depending on setup and driving style. I don't think it works well with a loose/flexible car because it really ties the front together. It also doesn't do as much with an aluminum chassis because that chassis is so stiff already.
I use it with a carbon chassis on asphalt and find that it makes the steering more direct.
Old 08-03-2016, 12:03 PM   #1797
PACaSteel's Avatar
I use one on carpet. It moves the top deck flex point forward resulting in more steering at a bit of a cost to traction. On the new carpet, you have all the traction you could ever want so there is really no penalty.
PACaSteel is offline   Reply With Quote
Old 08-06-2016, 10:37 PM   #1798
Slapjack's Avatar
What position are ppl running the front and rear diff in for carpet tracks? By position I mean where the tab piece sits in he bulkhead notches. Also what diff fluid works well on carpet?
Old 08-08-2016, 06:34 AM   #1799
Slapjack's Avatar
Does anyone order xRay parts from RcMart? Just wondering if the parts are authentic xray and if shipping times are decent since they are in HK. Prices look good but didn't want to end up with knock off stuff or something.
Old 08-08-2016, 08:25 AM   #1800
tbrymer's Avatar
Yes, they are authentic, genuine xray parts.
