Xray t4'15
#1771
Can a 2015 be swapped over to a 2016 chasis or are they completely different? Unable to find an avid alum chasis for a '15. So was wondering if a '16 would work.
#1772
The 2016 chassis will be fine.
#1773
The screws are excellent, even the aluminium ones are really strong. I've yet to damage any of them after ~5 months of use.
#1774
What are some other good upgrades for carpet? I have a TT alum chasis but may switch to the '16 avid alum chasis (just cause I can't find a '15 avid). But what about carbon arm stiffeners and other upgrades? Who makes arm stiffeners?
#1775
Honestly, I would just use the TT chassis because they work well and you own it. And, although you could go crazy with upgrades you don't really need them. Put that money into some tires and bodies and go have fun.
#1776
I have a Schuur speed 13.5 motor I am going to run and I think I want to get a vxx or vx3 orca esc. What esc is everyone running that is good for onroad? And I was going to run a Savox 1258... What servo is everyone running?
#1777
If you're sticking with Savox then the 1251 is what you want. The low profile servos fit the chassis and leave plenty of room for everything else. And, they work just fine for TC.
I'm sure any decent ESC will be fine for the spec classes. Really, a Hobbywing XR10 Just stock is probably everything you need so anything more is just icing on the cake. The Orca speedo's I've seen others run have been very good too but I've never personally ran one.
#1778
The VXX and VX3 are very good and reliable ESCs made by ORCA. You won't go wrong with it.
#1779
I wish I would have kept my vx3 and Savox low pro alum case servo from when I had my other t4. Damn it! Lol. But I don't think I want to get a esc permanently set for stock racing just in case things change. But right now they run 13.5. Would that be considered spec or stock with zero timing? Is spec and stock the same thing?
#1780
What spur and pinion size should I run with 13.5? The car came with a 106 spur and I currently have a 47, 50 and 51 pinion in 64p. Should I drop down to like a 96 spur or something like that?
#1781
Why is it some of the shims on the T4 are composite and others are aluminum. Just was wondering if there was a reason behind that.
#1782
I'm sure it's because the aluminum ones cost more but don't worry about it they all work just fine. Aluminum all around is certainly nice but it won't really matter to the way the car works.
#1783
I am going to be running on green carpet track. I already have an aluminum chasis. Are there any other parts I should consider for high traction tracks (graphite arms, alum c-hubs, floating servo mount, etc...)?
Also wondering about the Arms. The carbon stiffeners saying they are for the ARS arms. But will they work on non-ars arms? Not sure why they would only make them for the ARS
#1784
Don't know if it still applies to today's material but some manufacturers sometime back thought opposite materials (metal against plastic} have less friction and wear than similar materials (plastic against plastic).
#1785
