Like Tree1Likes
Old 04-21-2016, 10:40 AM   #1756
I'm trying to reduce the rear toe-in but no matter what combination of hinge pin inserts I use I can't get less than 3* Do I have to purchase the optional front hinge pin mount? I'm looking to get about 1.5 to 2* of rear toe in.
Thanks for any help.
outlandr91 is offline   Reply With Quote
Old 04-21-2016, 10:46 AM   #1757
erchn's Avatar
You should be able to use the .5mm wider in RF and the 1mm narrower in the RR, that will get you about 2.2. 1mm wider in RF will get you below 2mm.
One thing that can happen, if you are using a setup station is that the plastic piece on top can hit the body posts, so it doesn't seem like things are moving. Remove or just push aside the body posts.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 04-21-2016, 11:56 AM   #1758
Trader Rating: 33 (100%+)
using the pills in the rear.. you can use the 1* inside on the RR block.. on each side.. to get you 2* of rear toe.
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 04-21-2016, 06:03 PM   #1759
Yup, that did it, it didn't occur to me to turn the 1* block side ways Duh!
Can you answer another question? The manual shows an optional rear 1 piece suspension holder, #303711-0 that takes the place of the two stock ones. The manual says it increases steering, how does it do that? Thanks again for your help.
Old 04-22-2016, 06:53 AM   #1760
R Dodge's Avatar
It makes the rear of the chassis more solid, reducing rear traction.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is online now   Reply With Quote
Old 04-22-2016, 10:37 AM   #1761
Thanks for answering
Old 04-22-2016, 10:58 AM   #1762
Skiddins's Avatar
Depending on conditions and setup, it can help with rotation, and/or, make it difficult to drive.
Must be said, you rarely see it in team driver setups.
I assume they are more interested in the extra traction from split blocks
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-22-2016, 12:09 PM   #1763
I think I'll find another way to get more steering, I just saw it in the manual and was curious about it. Ya never know unless you ask
Old 04-22-2016, 03:41 PM   #1764
Skiddins's Avatar
Definitely changing the pivot block inserts to reduce toe will help.
Remember you can also use the different combinations to reduce rear track width whilst reducing the toe as well which can help with steering and rotation
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-03-2016, 08:06 PM   #1765
Hey guys, I was just on the Xray site trying to find a good low to mid grip asphalt setup any suggestions?
Old 07-03-2016, 08:28 PM   #1766
Look down the list for the 2015 setups
http://site.petitrc.com/reglages/xra...etsXRayT4.html
malkiy is offline   Reply With Quote
Old 07-04-2016, 08:33 AM   #1767
Thanks for the link.
Old 07-12-2016, 04:57 PM   #1768
Slapjack's Avatar
Trader Rating: 19 (100%+)
Can I use the hiro seiko t4 2016 screw kit on my 2015? Or are a lot of screws different sizes? Or does anyone know where I can get a 2015 set? Anyone used those Twork's brand screws on eBay? Any good?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 07-13-2016, 12:12 AM   #1769
daleburr's Avatar
Yes it'll work fine, cars are identical screw wise.
Team Xray
daleburr is online now   Reply With Quote
Old 07-13-2016, 06:57 AM   #1770
Slapjack's Avatar
Is the hiro seiko a good screw kit? Is that everybody uses? It's the titanium and orange alum kit. I want to use the alum on the top deck and titanium on the chasis bottom and everywhere else
