Like Tree1Likes
Old 10-21-2015, 05:41 AM   #1711
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by cplus View Post
5mm is definitely a good start. Typically you will want to run a little rake - say 0,2mm front to back (ie: 5,0 front 5,2mm rear)
How far forward or back you mount the body can affect handling also. Typical is 5mm off the bumper foam.
Originally Posted by erchn View Post
Yep, 5mm, set that first then use the Sharpie method. If concerned be conservative, it's always easy to cut more.
Thanks guys... Yea, I tried to set it directly over the front wheels. That is how I had it lined up but then I popped the holes in and of-course it shifted . Im sure it will be fine. This is the first on road car I will have driven so I won't even notice if the handling is off. I would think having the body forward would make it have more aggressive steering? Is that right?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 10-21-2015, 05:51 AM   #1712
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Yeah, could make the car feel twitchy in high speed areas, and lack a little rear grip in high speed corners.
3D-Seth is offline   Reply With Quote
Old 10-21-2015, 05:56 AM   #1713
R Dodge's Avatar
Yes, it will give more steering like that. I wouldn't worry about it, you might find that you want the extra steering. Most of us run the body a couple mm forward on purpose for that exact reason.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 10-22-2015, 11:32 AM   #1714
TimmyMontoya's Avatar
$190 to upgrade your 15 to a 16!! Really good deal!!!
http://www.discountrcstore.com/mobil...ode=T415update
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 10-22-2015, 06:18 PM   #1715
MinnesotaJoe's Avatar
R/C Tech Elite Subscriber
How much of this would work on a 14?
MinnesotaJoe is offline   Reply With Quote
Old 10-22-2015, 08:11 PM   #1716
Trader Rating: 20 (100%+)
I'm not sure I'd bother. The '16 has some small changes over the '15 but I'd bet that overall most people can't tell the difference between them. And, for that price you can sell your '15 and get a new '16 for the difference.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-22-2015, 10:36 PM   #1717
The chassis and motor mount part won't work on the 14. Xray had a big jump from the 14 to the 15. Trying to upgrade from the 14 to 16 would require more parts and by the time you get those you should have just purchased a 16. Hope that helps.
Old 10-23-2015, 05:37 PM   #1718
mschumi101's Avatar
Send a message via Skype™ to mschumi101
The only additional thing you would need for the 14 would be the servo mount. But as others have said, its more cost effective to just sell and buy a whole new car. The sway bars/bulkheads would be different, but everything else would still bolt on to the 16 chassis plate.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 10-24-2015, 09:57 AM   #1719
metalnut's Avatar
Trader Rating: 36 (100%+)
To me, the sway bar setup alone is worth an upgrade to a 15/16, looooove that design.
- Ricky Bobby
Old 10-26-2015, 09:15 AM   #1720
Trader Rating: 33 (100%+)
post up pictures Slapjack..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 10-26-2015, 06:49 PM   #1721
Slapjack's Avatar
Here is a couple pics. After I moved the body on the posts it doesn't look as shifted now. I still have to drop the ride height down some so idk if it will effect it. But where it sits now it seems pretty centered I think
Old 10-26-2015, 06:50 PM   #1722
Slapjack's Avatar
Another pic
Old 10-26-2015, 06:55 PM   #1723
Slapjack's Avatar
I posted this in the main on road forum but I figured I could get a good answer here too. I am wondering if the hudy setup system for onroad touring car will also work for my xray xb4 10th scale buggy? Or if the 10th off-road would work on my t4. I just don't want to buy 2 stations. Also wondering if anyone has used any other station that is good. I was looking at the gforce one it comes with a case for like 115 or the arrow max one around the same price without a case. Then there is integy but not sure I like the gage system for the toe in/out. It isn't a acrylic like all the others it is aluminum and mounts completely different. Any advice?
Old 10-26-2015, 06:59 PM   #1724
SpidarX's Avatar
Another pic
Looking good. I like that the car is getting blessed by an angel in the background.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 10-26-2015, 07:30 PM   #1725
Slapjack's Avatar
Lol. I didn't notice that. All my wife's grandmothers stuff is all stashed away in that back corner of the basement
