Like Tree1Likes
Old 10-06-2015, 07:14 PM   #1681
Slapjack's Avatar
Trader Rating: 19 (100%+)
These are the pill inserts I used
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 10-06-2015, 07:38 PM   #1682
SpidarX's Avatar
Originally Posted by Slapjack View Post
Wondering what I should be runnin for toe in in the rear? I have the standard rear setup (not ARS) and I just stuck the .5mm pills in but it looks a little too much. Maybe would the .5 deg pills be better?
Obviously it depends on the handling characteristics of the car, but it's best to start with the kit settings if you are new.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 10-07-2015, 02:45 AM   #1683
Skiddins's Avatar
I like it... Looks good. But orange is probably my favorite. Anyone done a green one?
I recall someone doing green a few years ago, but it did have a very matt finish to it.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-07-2015, 04:35 AM   #1684
daleburr's Avatar
The HoBao looks pretty gross in green, that's definitely an acquired taste!
I really like the Kyosho red... but not enough to go through the pain of owning one, or reanodizing my Xray. The orange grows on you
Team Xray
Old 10-07-2015, 10:52 PM   #1685
TryHard's Avatar
If you using the standard insert in the front block, then this setting will give you 3.5deg of rear toe, which is quite a lot.
Personally, I've been liking having a 0.5 out on the RF and 0 on the RR block, for 2.5 of rear toe.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
TryHard is offline   Reply With Quote
Old 10-08-2015, 07:38 AM   #1686
Trader Rating: 33 (100%+)
just something to think about. if you go to the xray website... and download the XB8 manual.. thats the offroad buggy.. page 13 has a really good explanation for the pills.. and how they work.
go check it out..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 10-14-2015, 08:10 PM   #1687
Fastforward's Avatar
Default set-up for USGT
Can someone suggest a starting set-up for USGT, low - medium grip carpet. Pretty small layout.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 10-14-2015, 08:33 PM   #1688
Fyrmed2's Avatar
92/48 here on a small track.
Hobby Town USA - Lake in the Hills
Timewarp Raceway
IAFF Local 2392
Fyrmed2 is offline   Reply With Quote
Old 10-15-2015, 09:38 AM   #1689
here is my setup for 17.5, should be good.. just adjust the gearing..
http://forum.teamxray.com/xform/inde...&setup=t4_2015
Daniel Grobe
Sponsors:
Old 10-15-2015, 12:29 PM   #1690
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
How is the kit carpet setup behaving for you? You should definitely start there.
- Ricky Bobby
Old 10-18-2015, 11:24 AM   #1691
Which DCJ`s is recommended? Cant find Xrays 52mm in stock...
MarcusEngdahl is offline   Reply With Quote
Old 10-18-2015, 11:38 AM   #1692
hanulec's Avatar
Trader Rating: 27 (100%+)
Floating Steering for T4'15 from Radtec now available
http://shop.rochercusa.com/index.php...product_id=171
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-18-2015, 07:05 PM   #1693
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Have a '16 on the way, but figured my question was the same for both cars, and since this thread has a little more traffic, figured I would ask here.
I'll be running an Orion speedo on my T4, so will have two sensor wire mounting locations, but what length sensor wire are most people using in this car? Need to order a few last items and figured I'd throw a sensor wire on that order.
Thanks!
Seth
3D-Seth is offline   Reply With Quote
Old 10-18-2015, 07:08 PM   #1694
3D-Seth's Avatar
Looks like TQRC has the XRay 52mm in stock..
http://www.tqrcracing.com/shop/produ....asp?p_id=9801
Old 10-18-2015, 07:14 PM   #1695
alecladanga's Avatar
1. radtec has DCJs, just check the link posted by hanulec above
2. you could also look at arrowmax
3. spec r and team c also have DCJs for the xray.
