Like Tree1Likes
Old 10-02-2015, 11:41 AM   #1666
Trader Rating: 33 (100%+)
i use the hudy setup station.. but there are many other options..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 10-02-2015, 01:28 PM   #1667
Slapjack's Avatar
Trader Rating: 19 (100%+)
I didn't mean different brand stations, but rather... Doesn't Hudy have different stations for on-road?
Anyone run Futaba 204GF-E receiver? All my other receivers are the telemetry ones and the 4 channel with antennas. I am just wondering does the range on the GFE (one with no antenna) suck? Or is it reasonable? It says 230' or 70m but can't really judge if that would be enough. I am used to 8th scale stuff so tucking an antenna somewhere isn't a big deal but these 10th scales are pretty limited on space.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 10-02-2015, 01:30 PM   #1668
they have an all included setup kit.. that has a tweak station, and stuff like that.. i got just the setup station..
Daniel Grobe
Sponsors:
Old 10-02-2015, 03:25 PM   #1669
Osiris 75's Avatar
Trader Rating: 17 (100%+)
It will specifically say say 1/10th on-road set up station...
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 10-02-2015, 06:24 PM   #1670
Slapjack's Avatar
Ok thAnks. Are the purple Hacker motors a good motor for mod? I got the 17.5 trinity d4 but I just came across a hacker 5.5t
Old 10-03-2015, 09:18 AM   #1671
Slapjack's Avatar
Am I understanding the FDR correctly when I say to start on the safe side ad keep motor temp low I would want to start with a higher fdr# (4.0) vs a lower fdr# (3.7) for example?
Old 10-03-2015, 05:00 PM   #1672
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Yes. Though too low of an FDR can have the motor spinning too fast and also make it hotter. But you're in a safe range. Don't forget that motor timing is also an important factor in the game.
- Ricky Bobby
Old 10-03-2015, 07:31 PM   #1673
Slapjack's Avatar
I'm running 96 pinion and I just ordered a 45, 47, 50 and 52
Pinion. But what about timing? I do know in the one class at my lhs timing has to be set to zero. But what should I usually run it at otherwise? Maybe stay below 50?
Old 10-04-2015, 12:04 AM   #1674
metalnut's Avatar
You're asking a lot of questions that aren't T4 specific and you'd probably get better/quicker answers in the appropriate forums. In general yes, most motors like to be below 50* of timing, but keep in mind that the marks on the end of the motor aren't always accurate to what the actual internal timing works out to be. Start with stock timing and a decent FDR, then crank it up a few degrees at a time, measuring motor temp after each full qualifier or race. Keep your motor below 160* of temperature.
Also, I'm pretty sure the "no timing" class you're talking about means no boost or any other timing advance on the ESC (also called stock or blinky racing). Motor timing (on the motor can itself) is almost always allowed, but do follow your track rules of course.
- Ricky Bobby
Old 10-05-2015, 06:47 AM   #1675
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Default One race old '15 for sale
If anyone is looking for a great carpet car, here it is:
Xray T4 2015, One Race, Roller
I purchased this a few weeks back, and only had intentions on running one race with it. That race is done, so I no longer need the car.
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 10-06-2015, 08:58 AM   #1676
Slapjack's Avatar
Just thought I would post this in case someone else was looking for an alternative to using tape for battery hold down and doesn't have time to wait to buy one and have it shipped.... Someone else has probably already posted something like this but oh well....
This was just a quick practice to see if it would work. I am going to redo it so it looks a little cleaner but, I took a couple pieces of Velcro straps (1 piece hook, 1 piece loop), removed the horizontal battery stops from the chasis poked a couple holes in the Velcro for the screws to pass through and another hole for the adjustable stops to pass through and then placed the Velcro on the chasis and the graphite battery stop on top of the Velcro and sandwiched them together by tightening the screws down. This way the strap doesn't have to loop under the chasis. I posted a couple pics. The strapis obviously long and would have to be trimmed to fit the specific battery.
Xray t4'15-image_zpsberzo4xb.jpg   Xray t4'15-image_zpsgkbzanv2.jpg   Xray t4'15-image_zpsgqgst8ag.jpg   Xray t4'15-image_zpshdsgfomc.jpg
Old 10-06-2015, 01:28 PM   #1677
Skiddins's Avatar
THis is what happens when a friend decides he wants something other than orange (and they can't do any sort of white, or a decent yellow lol)
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-06-2015, 01:49 PM   #1678
I think Hotbodies is not happy with this.(LOL)
eded1 is offline   Reply With Quote
Old 10-06-2015, 04:24 PM   #1679
Slapjack's Avatar
I like it... Looks good. But orange is probably my favorite. Anyone done a green one?
Old 10-06-2015, 06:13 PM   #1680
Slapjack's Avatar
Wondering what I should be runnin for toe in in the rear? I have the standard rear setup (not ARS) and I just stuck the .5mm pills in but it looks a little too much. Maybe would the .5 deg pills be better?
