Like Tree1Likes
Old 09-30-2015, 09:15 AM   #1636
Slapjack's Avatar
Trader Rating: 19 (100%+)
What lipo do I use in this car? Regular size stick packs with bullet connectors, right? I dont want a shorty pack correct?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 09-30-2015, 09:21 AM   #1637
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
Yes, full size packs with bullets would be the best option.
- Ricky Bobby
Old 09-30-2015, 12:13 PM   #1638
Slapjack's Avatar
Next question. I was about to order the RSD fan mount and the R1Wurkz fan. Fan says its 8.4v. Can I just plug that right into my futaba Rx? it says it can be wired directly to 2s lipo. But I would prefer to put it right to the Rx I think. How would you even wire it to the lipo?
where can I order a battery holddown that is in the states? I found the xray graphite hoddown which is like $45 but I also saw a couple Velcro strap type systems but didn't find them on a site that was in the US. A-Plus and CSO I think were the brands. Tape just seems like it would be a pain after awhile? Maybe??
This looks like it would be an easy way to secure the battery... anyone used it? But it says for 2014. is the 2014 holes for the battery stops different than the 2015?
http://www.ebay.com/itm/XRAY-T4-2014...item58be0b5cd9
Old 09-30-2015, 12:56 PM   #1639
erchn's Avatar
You can plug it into the receiver yes, but you can also wire it to the positive and negative poles on your ESC, that's what many do, it makes the fan push quite a bit more air.
Reflex also sells a battery hold down solution that is similar to the Awesomatix battery tabs, it works well. I personally just prefer to use tape, the best tape I've used is the Hudy tape...works perfect, replace it once a day and never worry.
I've not seen that system before, and would probably work, but one of the important things to remember is to not strap the battery too tight to the chassis, it can create flex and stress in the chassis, reducing performance. Depending on how tight the o-ring is it could be detrimental.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 09-30-2015, 01:18 PM   #1640
Slapjack's Avatar
Talking
Thanks for the responses....
Old 09-30-2015, 04:45 PM   #1641
Slapjack's Avatar
Ok guys I'm back with more questions about the issue Inposted with the bent top deck and gap between the lay shaft holder. After looking at this more I understand now I think. You are saying to use shims between the deck and bulkhead so the deck doesn't bend when screwed down... and there should be a gap between the deck and layshaft holder so it can flex more? Right? As if I want to use the lay screws I have to shim between the deck and lay shaft holder. I found some shims from RSD but I think they are for the lay shaft holder. Are there shims I can buy for shimming between the deck and bulkheads? The holes are so close together I can't use washers or anything because they interfere with each other.
These are a couple pics if where I need to shim so the deck is flat
Old 09-30-2015, 04:47 PM   #1642
Slapjack's Avatar
And also shim under the front bulk.
Old 09-30-2015, 04:48 PM   #1643
Slapjack's Avatar
And leave this gap alone... Unless I want to run lay shaft screws then I shim that too. But I would have to go back to the stock deck because this deck doesn't even have holes for those screws as you can see
Running no lay shaft screws would be for low traction tracks like asphalt and I would want to run them when it's high bite like on carpet?
Old 09-30-2015, 07:35 PM   #1644
tbrymer's Avatar
I think you are getting the idea now. I ordered my shims from here:
http://www.tqrcracing.com/shop/produ...asp?p_id=10205
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 10-01-2015, 01:51 AM   #1645
Skiddins's Avatar
Originally Posted by dgrobe2112 View Post
thought they would do some updated steering to be a full float steering..
Be thankful they didn't.
Perhaps it will be an option
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-01-2015, 06:30 AM   #1646
Slapjack's Avatar
Has anyone in the states ordered from A+ Rc Products in Hong Kong? I was going to order this but I don't know about ordering from overseas
http://www.a-plusrc.us/t4-aluminum-7...battery-mount/
Old 10-01-2015, 07:56 AM   #1647
Trader Rating: 20 (100%+)
I don't like the Velcro style battery hold downs for TC. Stick with tape or one of the better hold downs like the RSD version.
http://www.reflexracing.net/RSD-Batt...AY_p_1343.html
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-01-2015, 08:22 AM   #1648
Slapjack's Avatar
Lol, I was just looking at the RSD mount (I just came across it when looking for a fan mount)... I was wondering, there is a gap between the tabs and the battery. Won't the battery shift or bounce?
Old 10-01-2015, 08:34 AM   #1649
You want the battery to allow the chassis to flex under it so this is a good thing.
That said...get this tape and be done. It's the easiest thing and it's what the fast guys do because it's the best option.
http://www.reflexracing.net/Hudy-Fib...ck_p_2224.html
Old 10-01-2015, 08:42 AM   #1650
Send a message via MSN to Emil
Not sure if you have seen this:
http://www.n1cholaslee.com/#!INSIDE-...f25fa7fe202309
Sharing is caring
Emil is offline   Reply With Quote
