Like Tree1Likes
Old 09-13-2015, 08:02 PM   #1561
finnyc's Avatar
R/C Tech Elite Subscriber
ArrowMax 48p work fine
finnyc is offline   Reply With Quote
Old 09-13-2015, 10:46 PM   #1562
Trader Rating: 20 (100%+)
Try ARC spur gears. I've used a couple and they were just fine.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 09-14-2015, 12:33 AM   #1563
Barry_Hughes's Avatar
Originally Posted by Kevin Marcy View Post
Are there any other brands of spur gear that fit this car? Kimbrough & Robinson appear to be too thick.
try searching this thread for spur gear
this question has been asked many times and there are many makes that fit
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 09-14-2015, 06:02 AM   #1564
Trader Rating: 29 (100%+)
Hey Kevin,
My favorite are the Leespeed gears. Eric Anderson has them on this site. http://www.teameamotorsports.com/ind...product_id=122
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 09-14-2015, 11:36 AM   #1565
metalnut's Avatar
Trader Rating: 36 (100%+)
I like Xray spurs, but Serpent spurs fit as well. The Serpent spurs aren't offset, which can be good or bad depending on what pinions you use.
- Ricky Bobby
Old 09-14-2015, 03:16 PM   #1566
rangerjkb's Avatar
Trader Rating: 38 (100%+)
Send a message via MSN to rangerjkb
Leespeed, RW, Xray, Panaracer spurs will fit with no modifications and I imagine there are several more.
rangerjkb is offline   Reply With Quote
Old 09-19-2015, 09:16 PM   #1567
carrotcake's Avatar
Hi guys, T4 2015 newbie here. I recently bought a brand new kit (haven't build it yet) but are there any "Known" issues with the kit that requires to ask Xray to send replacement parts? or any other known issues with the kit? I also bought a Xb4 2015, heard there were problems with the rear toe and Xray was sending out replacement parts to fix that issue. So just wondering if the T4 has the same type of problem. Thanks.
carrotcake is offline   Reply With Quote
Old 09-19-2015, 11:46 PM   #1568
metalnut's Avatar
Some 2015 T4 kits had bad QA when it came to the shock parts bag. I would build the shocks first to make sure everything is there. Otherwise the kit is solid and builds like a dream.
- Ricky Bobby
Old 09-20-2015, 04:34 AM   #1569
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Which aluminum chassis does the group like? How many are there for the 2015 car? Xray and Avid are the ones I know about. Any others? What are the Pros and Cons of these?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 09-20-2015, 04:57 AM   #1570
carrotcake's Avatar
Good to know. Thanks a bunch!
Old 09-20-2015, 06:44 AM   #1571
R Dodge's Avatar
Snowy.
I actually never got the Xray alu chassis to try but I'm currently running the avid alu chassis and love it. Lots of steering and corner speed with the avid chassis. Fit and finish on the avid is great as well. Of course the Xray quality is top notch as well, though I think the Xray chassis is a little heavy
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 09-21-2015, 11:15 AM   #1572
Trader Rating: 33 (100%+)
the avid chassis is great.. all the nice etching.. sofar.. i am happy with it. although i cant compare it to anything else.. i can compare the avid carbon, and the stock carbon.. and the avid carbon with the 1.5 top deck.. are money..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 09-21-2015, 11:26 AM   #1573
oladele's Avatar
Snowy.
I have driven the XRAY chassis for several months, and switch to the Team Tamale. the finish of both are great. The Team Tamale offers a little more flex then the XRAY. The Team Tamale chassis is 20g lighter than the XRAY. They are both excellent choices. Avid is also an excellent choice as well.
oladele is offline   Reply With Quote
Old 09-21-2015, 01:45 PM   #1574
metalnut's Avatar
How did you adjust your setup for the Tamale chassis, if I may ask?
- Ricky Bobby
Old 09-21-2015, 01:53 PM   #1575
tbrymer's Avatar
Default Front Arm Pivot Pin shims
Does anyone use shims on the front arm pivot pins? The pin that holds the chubs on. I have a little more play than I like and was wondering where to get some shims.
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
