Like Tree1Likes
Old 09-03-2015, 06:00 AM   #1531
R Dodge's Avatar
Originally Posted by SpidarX View Post
I've seen a number of people recommend placing .5 shims under the top deck. I assume this creates more flex. Under what conditions would you do this? I would like to hear some opinions of whether this is a good setting.
Originally Posted by tbrymer View Post
I can tell you all the fast guys are doing it That's about all I know. I think some are even using 1mm shims.
Generally you'll use the shims when you don't want the topdeck to touch the layshaft bulkheads, this way when the topdeck flexes it does not bind on them. This generates more traction.
Originally Posted by thomasd View Post
Has anybody tried the 2.25 or 2.5 mm arrowmax top deck for high traction carpet
I haven't used Arrowmax, but I've used pretty much the entire spectrum of Avid topdecks. With the aluminum chassis on carpet I have found the 1.5mm soft and hard Avid topdecks to be really good on really any grip level. I tried the 2.0mm hard on high bite and it was okay, but I preferred the feel I got from the 1.5 topdecks. Soon I will test the carbon chassis with the Avid 2.0 hard topdeck.
Originally Posted by Jamie Hanson View Post
What are peoples thoughts on the ARS system? I have not really seen much chatter about it.
I've tried it a little bit, most recently was the week before our Charity race at JMR. I didn't like it personally, but the track was also a little bumpy then before the re-pave. Europeans seem to like it mostly for high bite, smooth and flowing asphalt tracks.
I also tried it at IIC last year when the car first came out. Alex did as well, we all ended up going back to the standard suspension that week. For carpet I think you'll always want the standard rear suspension.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 09-03-2015, 09:02 AM   #1532
daleburr's Avatar
Tried it twice on low/medium grip tarmac and didn't like it. Even set to 3.2deg toe it had very little rear grip. Probably works okay on RIDE tyres (which understeer a lot) in high traction conditions, but not much use for UK racing.
The PSS inserts are good though, they're worth having. More stability and consistency with minimal loss of steering. Couple of setup changes and you've then got more steering and more consistency = better laptimes.
Team Xray
Old 09-03-2015, 10:52 AM   #1533
Trader Rating: 20 (100%+)
Are you pairing progressive springs with the PSS like Alex and other Xray drivers are or are you using something else?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 09-03-2015, 04:15 PM   #1534
Trader Rating: 28 (100%+)
Do most guys run boost in there cars. Car has a 6.5t and trying to see if its ok to add boost or run in blinky.
Thanks to my sponsors
Proline racing Sidewinder Fuel 4C Hobby Supply Upgrade-Rc Psm-Rc Rcdepot.ca RcAmerica Hudy Xray
kyok2 is offline   Reply With Quote
Old 09-03-2015, 04:16 PM   #1535
erchn's Avatar
I'd highly recommend running at least one boost, it'll take the esc out of blinky mode, and make it smoother. Most ESCs in blinky mode turn into light switches.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 09-03-2015, 04:18 PM   #1536
Ok thanks. I will try it this weekend. Will be my first onroad race.
Old 09-03-2015, 07:32 PM   #1537
SpidarX's Avatar
I just converted to it. Will give it a try this weekend.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 09-03-2015, 07:56 PM   #1538
Big track or small track? On a small track, just put in a pinch to smooth it out. On a big track you'll need a ton of boost to have any shot at keeping up with most peoples boosted 4.5t.
Old 09-04-2015, 01:07 AM   #1539
daleburr's Avatar
With the PSS inserts I've run Xray linear, Xray progressive, and RSD progressive.
The Xray linear springs (2.7) are best if the grip is low, as they seem to give a bit more bite and consistency. RSD progressives (silvers) are great if its hot and the grip is good. I haven't done enough running with the Xray progressives to figure out what their ideal conditions are. At my local track (low/med grip) the Xray linears were faster.
I've only had the PSS shocks for about a month though so more testing will be needed next outdoor season.
Team Xray
Old 09-04-2015, 02:00 AM   #1540
Skiddins's Avatar
Depending on track size, i'd be running boost 90% of the time with a 6.5 (I certainly did when running a 7.5)
If you want to run blinky in mod then a 5.5 for fairly small tracks and a 4.5 for anything larger should do.
The only place you'd lose out not running boosted is the straight.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-04-2015, 07:04 AM   #1541
Trader Rating: 17 (100%+)
Can someone explain how changing the arm inserts effects the car, I understand that they change how the arm sits but what do all the different positions mean
Team Awesomatix
R1 Wurks
RC Maker.com
Southern Tasmania Model Car Club
lethallee69 is offline   Reply With Quote
Old 09-04-2015, 10:41 AM   #1542
Barry_Hughes's Avatar
BY moving the arms outwards or inwards you can alter the width of the car.
by putting angle inwards or outwards you can add or reduce toe in or add toe out
You can alter the roll centre (up or down) if you move the arms level up or down
buy adding an angle up or down you can add anti or pro squat or anti or pro dive
best bet is to download the set up guide for the T4 13 it is basically the same or the Hudy set up guide
you can of course add any combination e.g. to lower the roll centre, add prodive and increase toe in
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 09-04-2015, 08:06 PM   #1543
Thanks for the explanation
Does widening or narrowing at the mounting points have the same effect as doing the hex's?
Team Awesomatix
R1 Wurks
RC Maker.com
Old 09-05-2015, 07:23 PM   #1544
theclutch's Avatar
Originally Posted by pcar951 View Post
Usually November or December. Thinking of making a change, a main?
Any news on this? I don't want to get a T4 '15 only for it to be obsolete when they release the T5 in November or December. Are there "sneak peeks" anywhere?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 09-05-2015, 09:53 PM   #1545
SpidarX's Avatar
Just tried out the ARS for the first time. At first the rear end seemed to be inconsistent. Sometimes it would loose traction, especially when going through chicanes. Added more rear camber and stood the rear shocks up a bit....really helped it out. The car rotated really well, and I could drive it much harder through the turns. So overall, I think it went pretty well. I used a static rear toe in of 2.5, and 3.0 rear toe in under full suspension compression.
Maclan Racing
