Like Tree1Likes
Old 08-21-2015, 05:56 AM   #1501
Trader Rating: 13 (100%+)
Originally Posted by SpidarX View Post
Does anyone use the motor guard on their t4? Does it actually help protect the motor? I got hit last week, and my motor can was slightly damaged.
I had one of these in my car a couple of years ago and one of the fast guys at my track told me to remove it. He said that with it sticking out the side and the bottom of it was level with the top of the chassis would cause it to rub in a corner due to the rolling of the car.
I don't know if this is actually true, but I haven't used it since and haven't had a need for one.
Has Xray changed the design? If not, you may still have the same problem when it is used.
tim
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 08-21-2015, 08:42 AM   #1502
alecladanga's Avatar
Need your help guys.
Was checking my rear toe with my hudy set up and my left rear toe is less .5 degrees compared to my right (standard rear set up, not ARS).
What i have checked are as follows:
1) inserts - black things with dots - right orientation - replaced it also but left still not aligned.
2) nothing bent - all straight, suspension blocks including shafts.
Don't know where else to look.
The rear toe was all right 4 weeks ago when I raced but no major crash. Just found out when I was rebuilding the kit.
Any suggestions to solve the issue would be greatly appreciated.
Old 08-21-2015, 09:09 AM   #1503
erchn's Avatar
Check your hexes, reseat them. Check toe, loosen the wheel nuts and rotate the axles a bit and recheck. It takes very little change, less that .4mm to get .5 a degree off, though I suspect your left/right difference is a bit less than that.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 08-21-2015, 09:38 AM   #1504
Trader Rating: 33 (100%+)
i was going to say the same thing.. bent outer lower hingepin.. outer hub carrier.. warped arm, bent axel? where the threads are?
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 08-21-2015, 06:46 PM   #1505
Thanks for the tips ans advice, will check the items you have indicated. Hope the problem is located there.
Old 08-21-2015, 07:16 PM   #1506
The scratches on my motor can point to "True".
Unlikely, because Hudy, and because it was measuring fine before, but... Measure one side, then flip the toe plate over to measure the other side. I battled an issue with my 3racing system for a long time, where no matter how carefully I set up the steering, I'd need a few clicks of trim to make the car track straight. Turned out the toe plate was reading a bit off left to right.
-Mike
Old 08-22-2015, 01:44 AM   #1507
Hey Guys,
is there anybody, who came from a TD DETC410 ?
Does both Chassis have the same Body mount holes?
Cause i want to buy a DETC410 and still have some bodies
fitted from a Xray T4?
Thx in advance
evotrf is offline   Reply With Quote
Old 08-22-2015, 01:24 PM   #1508
daleburr's Avatar
Originally Posted by evotrf View Post
Hey Guys,
Thx in advance
Don't do it! Things are cheap for a reason...
Team Xray
Old 08-25-2015, 01:19 PM   #1509
What is the best optionparts to get for this car?
Will be running on carpet low/mid grip....
Tnx! //Marcus
MarcusEngdahl is offline   Reply With Quote
Old 08-25-2015, 01:28 PM   #1510
wtcc's Avatar
Alu steering rack, ecs axles in front, no rear topdeck post, 0.5mm shims under topdeck, -.75 hexes in front, 2.6 and 2.7 springs and the RSD progressive spring set.
wtcc is offline   Reply With Quote
Old 08-25-2015, 03:26 PM   #1511
Skiddins's Avatar
As well as what the others have mentioned I would check that the RF toe blocks are aligned correctly, as you screw them in it's easy to twist them slightly, particularly the left side where you want the block to face out slightly, but tightening the screws from underneath try to twist it the other way
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-26-2015, 02:14 PM   #1512
Default Hexs
hi do you have a part number for the hex's
andrewd is offline   Reply With Quote
Old 08-26-2015, 02:30 PM   #1513
erchn's Avatar
305351
Old 08-26-2015, 08:33 PM   #1514
Thanks, I'll try this over the weekend at the track
Old 08-26-2015, 08:36 PM   #1515
spammy's Avatar
Does the avid aluminum chassis for the t4 15 fit the t4 14 just curious
spammy is offline   Reply With Quote
