Old 06-20-2014, 08:58 AM   #1
BIBOY's Avatar
Send a message via Yahoo to BIBOY
Default Is there a touring car ESC w/ hv bec? for HV servo?
looking for a 1/10 touring car esc the would have a bec output 7.4v i would to utilize my HV servos?
do you guys think this could benefit ep touring cars or is it a overkill? just want to see your thoughts on this
thanks
R1 Wurks
Xray
RC America
Reds Racing Engines
BIBOY is offline   Reply With Quote
Old 06-20-2014, 09:44 AM   #2
daleburr's Avatar
Tekin Gen2/RSX will do this.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 06-20-2014, 10:35 AM   #3
klaymon's Avatar
Trader Rating: 71 (100%+)
The Viper VTX10 series can be adjusted up to 7V.
klaymon is offline   Reply With Quote
Old 06-20-2014, 11:22 AM   #4
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Unless you're really looking for the speed and torque you get with the full voltage every HV servo I know of will run on 6v. And most have specs listed for them at that voltage.
Stop the hate! 'White Wheels Matter'
racer1812 is offline   Reply With Quote
Old 06-21-2014, 11:17 AM   #5
Trader Rating: 23 (100%+)
Tekin RSX/RS Gen 2 is the only ESC that has a true 7.4v BEC setting (you need the optional hotwire in order to activate the mode). To be honest though I doubt you'd need such a high power servo in a TC, furthermore I wasn't aware of any low profile HV servos from the major marques?
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-19-2015, 06:05 PM   #6
BIBOY's Avatar
Thank you!!
R1 Wurks
Xray
RC America
Reds Racing Engines
Old 01-19-2015, 06:22 PM   #7
hairless_ape's Avatar
I use one of these in all my cars running HV servos. They get their power straight from the lipo balance port.
hairless_ape is offline   Reply With Quote
Old 01-20-2015, 02:04 AM   #8
The issue with using HV servos in EP cars (when running off your main lipo) is degradation of performance over the run.
For a typical 6min run, you start at 8.4V and finish at 7.4-7.6V - it's not much, but the drop in servo performance means you would be constantly micro adjusting your lines. Hardly ideal for consistency.
A stable BEC voltage is much better, be it 6, 6.6 or 7.4v.
Besides the speed and torque specs of modern LP servos are more than adequate for rubber tyres.
cplus is offline   Reply With Quote
Old 01-20-2015, 02:07 AM   #9
Cole Trickle's Avatar
+1
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-20-2015, 03:11 AM   #10
Salkin's Avatar
Totally agree.
You need to install a UBEC to feed the receiver and servo with a constant voltage. This increases weight, which maybe is not a problem if your car is underweight.
But you can find many low profile servos that are fast even on 6V.
Haven't heard any of the "pros" doing this.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 01-20-2015, 03:54 AM   #11
Plenty fast and ample torque. Infact, most of the time people put a little expo on the steering or slow down the rate.
HV is really about torque for 1/8th buggies and 1/5th scale stuff. The best HV stuff is not really any faster than the best 6V low profile servos, but damn the torque figues are high on some.
My throttle/brake servo has 35kg/486oz.in torque and still does 0.13 transit.
And that's at 7.4V and I feed it with a 8.4V lipo....!
Zip. Never seen any do this.
The sanwa SRG-BLS V2 appears to be in >50% of the top 1/10 TCs
Old 01-20-2015, 04:21 AM   #12
Castel esc's have adjustable bec's also.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 01-20-2015, 05:01 AM   #13
Are any of them approved for racing though (serious q)?
Old 01-20-2015, 06:14 AM   #14
And Graupners Pro series ESC's also have adjustable BEC...
Foodie is offline   Reply With Quote
Old 01-20-2015, 07:22 AM   #15
A HV servo doesn't perform any better at 8.4v than it does at 7.4v. The stated 7.4v numbers are it's peak.
Your argument is invalid.
