Old 06-23-2014, 04:59 PM   #31
Could be a typo, but states the same here.
mosssman is offline   Reply With Quote
Old 06-23-2014, 05:09 PM   #32
EDWARD2003's Avatar
Yeah, I wouldn't trust this article in its entirety. Wait until trinity comes out with their own write up then you can complain about it.
http://www.rcnews.net/2014/06/23/tri...ops-the-new-d4
EDWARD2003 is offline   Reply With Quote
Old 06-23-2014, 06:44 PM   #33
Logi Maker's Avatar
Trader Rating: 49 (100%+)
With all the 3.5 BS... I wonder if/how long it will take to be ROAR approved...
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 06-23-2014, 07:44 PM   #34
Condor Speed's Avatar
Is already Roar approved.
Top photon EX 13.5 Trinity D4, Lrp Flow Works R1 Lipo
Top Photon EX 25.5 USVTA Novak Fanton Lipo
Xray NT1 Picco
Desoto Racing
RC Target
Condor Speed is offline   Reply With Quote
Old 06-23-2014, 08:57 PM   #35
evochick's Avatar
I don't see it on the Roar list or in the Roar approval forums yet ? so until its there it isn't legal.
(it may have been sent and approved but Roar still need to put it on the list)
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 06-23-2014, 09:24 PM   #36
Originally Posted by mosssman View Post
Uses All D3.5 KillShot Stators
Regardless of this being a typo and should say "rotor" perhaps it means you *can* use Killshot rotars/stators, not that is uses one out the box. Ie, all your spares are good still.
cplus is offline   Reply With Quote
Old 06-23-2014, 09:51 PM   #37
Logi Maker's Avatar
Not on any ROAR list.
Kyle Predmore
B6D|B64D
Old 06-24-2014, 12:59 AM   #38
smokinu's Avatar
Trader Rating: 60 (98%+)
They are waiting for the dealer spacifics of the roar part to be handled. First shipment should handle this and it will be on roar list by the end of next month.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 06-24-2014, 06:30 AM   #39
d16dcoe45's Avatar
Originally Posted by howardcano View Post
At peak horsepower and 8V, a 17.5 motor draws about 90 amperes. Of course, the gearing is set so the average draw is much less.
Wouldn't that mean that at peak and 8v you are seeing 720 watts from a 17.5? That is around 1 hp!! That 90w figure doesn't add up.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-24-2014, 07:17 AM   #40
howardcano's Avatar
Trader Rating: 35 (100%+)
I believe you meant 90A.
Your calculation is for input power. Output power is much less (by at least 50%).
But this does illustrate why they get so hot! A 540 motor can't dissipate 360W for very long before it melts down, so we gear for temperature. (Almost all of the normal motor/battery combos we run are similarly thermally-limited.) Not to mention that the batteries wouldn't last for the length of the race. And then of course there's the mitigating factor of not using full throttle for a large portion of a lap on a typical road course.
We were talking about the tabs, and although they don't look much different on the D4 versus other motors, oversized tabs could be a useful way to dissipate some heat. Maybe we'll see that in the future.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-24-2014, 07:20 AM   #41
shoman24v's Avatar
Trader Rating: 14 (100%+)
Sucks to be the guy who bought the prototype for $500.
| HPI Blitz ESE | Reedy Mach 2 9.5 |Schumacher Cougar SV2 | (2) Team Associated RC10T | Shelfer/Runner | (2) Team Associated RC10T2 Shelfer/Runner | Team Losi XX & XX-T & XX-T CR Graphite Plus Shelfers | Team Losi XXX-4 Shelfer |
shoman24v is offline   Reply With Quote
Old 06-24-2014, 07:31 AM   #42
daleburr's Avatar
Tested quite a few 17.5s on my dyno. Current draw at peak power is usually around 55A. Peak power output is around 200W. This is from an 8.4v lipo.
Efficiency at peak power is around 40%, rising to a max of about 70% before trailing off.
Here is a Vampire 17.5 in blinky mode at max endbell timing.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 06-24-2014, 07:37 AM   #43
http://www.trinityrc.net/shop/index....product_id=610
Go buy one
RedFormula2K is offline   Reply With Quote
Old 06-24-2014, 08:07 AM   #44
I'll wait for the new PULSE...
Ultegra is offline   Reply With Quote
Old 06-24-2014, 08:10 AM   #45
howardcano's Avatar
Thanks for the data, Dale. Did you measure the LiPo voltage during the run? It looks like the IR is pretty significant in your test, causing a large voltage sag. (This would not be surprising, given the low terminal resistance on a 17.5.) The low current draw and the fact that the power peak isn't at 1/2 the free-running RPM are clues for me.
If you'd like to discuss in a more suitable thread, let me know; I'm very interested. I'm sure you have plenty of practical experience to share!
Howard Cano
