Old 06-22-2014, 08:54 AM   #16
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Looks heavy to me ... needs to be innovative ... like wire tabs on other end of motor or the ability to flip the rotor or something so us onroad guys dont have our wires hanging out the side
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 06-22-2014, 09:24 AM   #17
d16dcoe45's Avatar
I love the wire tabs!! Very thick, looks like they can take some serious current. Whats the point of thousand strand 12g wire, heavy duty 5mm battery plugs and 90c lipos if the motor wire tabs aren't able to take the current?
I don't know if any other motors currently have these thick tabs (New Peak/Orion motors maybe?) but I bet you will start seeing them on new generation motors.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-22-2014, 03:13 PM   #18
DBM
We aren't drawing enough current to justify the weight of tabs like those. But whatever helps to sell motors I suppose.
The tabs on the current crop of motors still isn't the smallest link in the chain. ...it is the little leads on the FETs in the esc, and the traces on the PCB between the fets and the terminals.
DBM is offline   Reply With Quote
Old 06-23-2014, 06:33 AM   #19
d16dcoe45's Avatar
In 17.5 no, we aren't drawing a lot of current-maybe 25a max. A 4.5 mod TC can draw 100a + at peak draw though.
Each FET only has to deal with a small percentage of the total load since there are a number of FETs to share the current. Same with the traces on the board--if you have 8 FET each trace only has to carry maybe 3 amps total if running 17.5.
The 2-3 gram weight penalty of the thicker tabs will at least lower the total resistance if they do nothing else.
I appreciate the fact they they (Trinity) are trying new things and pushing the envelope. There are SO MANY competitive motors at this point that you have to innovate just to be able to stay in the game.
Jay Lestingi
Old 06-23-2014, 07:59 AM   #20
howardcano's Avatar
At peak horsepower and 8V, a 17.5 motor draws about 90 amperes. Of course, the gearing is set so the average draw is much less.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-23-2014, 03:59 PM   #21
Super Moderator
racer1812's Avatar
Trader Rating: 28 (100%+)
solder tabs...It's a pre-production prototype test motor, you'll lkiely never see those in production, and they're not needed. Some of you get all excited and I just laugh.
Stop the hate! 'White Wheels Matter'
racer1812 is offline   Reply With Quote
Old 06-23-2014, 04:02 PM   #22
patorz31's Avatar
Looks like the solder tabs came over in the production one.
http://www.rcnews.net/2014/06/23/tri...ps-the-new-d4/
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 06-23-2014, 04:02 PM   #23
joelwhite's Avatar
Trader Rating: 55 (100%+)
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 06-23-2014, 04:22 PM   #24
Super Moderator
racer1812's Avatar
True. When I looked at the eBay pic with the brass tabs, they blended into the fiberglass insulator, making it look thicker than it was.
Nothing special then, on either the pre-production or production version. Simply a slightly larger soldering surface, nothing new there, it's the same as a tab.
Old 06-23-2014, 04:47 PM   #25
Jerz616's Avatar
Trader Rating: 49 (100%+)
That article tells us that the new D4 is using the Killshot series stators. I wonder if we are going to see some go up in smoke right out of the box. I never had any issues with my KS, but I got rid of it before it could. When I did have it, it ran like a beast. Looking forward to seeing the new D4.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 06-23-2014, 05:13 PM   #26
"The new D4 is 8 grams lighter than the D3, and features an all-new stator design. Equipped with high temperature copper wire, infinite actual timing adjustment, new 3-piece can, new endbell, and increased venting, this is the most technologically advanced Trinity motor yet. The D4 motor uses KillShot series stators, and is available in both Spec and Modified versions."
I find it funny that there are comments that are not even remotely based on fact...
mosssman is offline   Reply With Quote
Old 06-23-2014, 05:16 PM   #27
Additional information from Trinity's website:
Meets all ROAR Specs
New Stator Design
High Temperature Pure Copper Wire
Certified Wire Guage
Infinite Actual Timing Adjustment
New 3 Piece Can
New Style Endbell For Better Bearing Alignment
Easy To Solder Silver Plated Tabs
Increased Venting For Better Cooling
NdFeB Neodymium Magnets
Grade 5 Ball Bearings
Uses All D3.5 KillShot Stators
Old 06-23-2014, 05:21 PM   #28
Trader Rating: 20 (100%+)
That quote contradicts itself. Is it an all-new stator design or a KillShot series stator?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-23-2014, 05:25 PM   #29
http://www.rcnews.net/2014/06/23/tri...ops-the-new-d4
I did not write it, the post that lists the source of the information is above, and quotes the source as Trinity.
Old 06-23-2014, 05:42 PM   #30
evochick's Avatar
I am guessing that last line is probably a typo,
probably should say
Uses All D3.5 KillShot Rotors
UnRetired
evochick is online now   Reply With Quote
SEO by vBSEO 3.5.0
