New comer need help
New comer need help
Hi everybody,
I am a new comer from HK.
I have a question and would like to have your help. I have just brought a Tekin BC112A H31 battery charger. Is it able to charge the 3000 NiMh battery. BTW, how does it compare with Novak Mill (not pro).
Thanks a lot!
Thanks a lot!
Use the P0 program...it will charge 3000 Nimh fine.......
I consider the Tekin better than the Novak.....no frills....does the same job over and over again!!!
Thanks a lot ah!
I am now have confident to use this charger.
Since why I ask was because when I compare the display data of both charger and found that Novak has a higher value than Tekin. Also Novak Mil seem to be a latter product (I don't know actually). Would you also advise which one is newer?
Thanks again!
Thanks again!
Just to let you all know Tekin went out of business. So take special care of your Tekin stuff because you wont be able to get them fix if anything happens.
Hi TC3MIKE,
Thanks a lot!
Actually I heard this news just after I bought the charger in the 2nd hand market. It makes me feel a little bit worry on the product. I doubt that the shop keeper has not told me the truth on whether it can handle 3000 NiMh as good as Novak in order to sale it out. I then try to found out any manual or review of the product to prove that in the web. But I did not success until I talk to you guys here.
Many thanks!
Cheers/MR4-tc
Thanks a lot!
Many thanks!
Cheers/MR4-tc
