Is there a variable rate discharger available?
I'm looking for a stand alone discharger that has variable discharge rate from 1 to 30 amps and also has variable voltage cut off. Does such a thing exist? I have looked around some and can't seem to find such an animal.
Straight Ltd. Fortress Battery analyzer.
I don't know, but would it be possible to increase the discharge on the Smart Tray? 10 amps would be fine with me, but 2.7 is really weak... :(
-Josh |
I certainly hope Tekin revives this discharger ! :D |
Originally Posted by Ghostfit
You're talking about a Tekin DIS-350 discharger .....only problem is that you'll have to look around, ebay maybe.
I certainly hope Tekin revives this discharger ! :D Wow, I'll have to take a look around. I use a Tekin BC112c with h31 software already. It would make a great pair. |
Roy.. check out the Fortress. it can discharge your packs at any amp desired.. and you can import them into a PC, graph and find out what the voltage reading is through out the entire discharge curve.
its great for finding out what pack is "race worthy" and what pack isnt. :nod: |
Thanks! Who makes the Fortress?
