Old 08-23-2005, 07:42 AM   #1
Default Leverage/Shock Geometry
What is the rule of thumb for changing spring rates when moving shock mounting positions? Example; If running the rear shock tower on the front of a TC3, still using the outside hole on the tower, how should the spring/oil/pack be changed?
Slow4dr is offline   Reply With Quote
Old 08-23-2005, 08:46 AM   #2
sosidge's Avatar
When making changes to a car setup, the aim is to just change one thing at a time, and keep everything else as consistent as possible, so you can really notice the difference your single change makes.
In the example of fitting a rear shock tower to the front of the TC3, my attitude is you should leave everything else (spring rate, oil, piston) as before. The only changes you may need to make to the shock is a slight change of pre-load to get the ride height to where it was.
The point of running the rear tower up front is the change it makes to the handling! You shouldn't make immediate changes to compensate for it. Just run it and work from their.
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 12:04 PM
Touring Sedan Geometry - Which is the best of out of the box? The Contender Electric On-Road 2 01-04-2005 09:28 AM
NTC3 Shock and Team Associated Shock Caps Question jcrouse Nitro On-Road 4 07-13-2003 09:11 PM
Front end geometry jcr Electric On-Road 12 06-20-2002 07:51 AM
Resources for Suspension Geometry Design Potato Electric On-Road 7 02-10-2002 07:53 PM
SEO by vBSEO 3.5.0
