Old 09-22-2014, 12:59 PM   #31
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Better yet, get a SupaStox or a Mardave and do GT12 right. We're running GT12 in Madison and following the rules. One of the guys already has one of these and they are very nice bodies. This is a very cool body with the right size tires on it.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-22-2014, 09:48 PM   #32
Car Breaker's Avatar
Originally Posted by M3Roc View Post
I have mine on an X12 as well and I agree, a bigger tire would fill in much better. I think that the next one I paint, I will use a razor compass to cut out the proper tire size and not use the lines molded into the body. Ill take a better shot of the side to show the wheel gap.
I run on asphalt therefore big tire is a plus fot me. Speedmind has 52mm of the rear tire that Icut to 48 which will look perfect with original wheel opening.
I run thw shell twice and my impression is that it cannot handle mod class but very stable and easy to drive with 10t+ motor speed
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-22-2014, 11:38 PM   #33
Clawhammers's Avatar
What would be the ideal tires' diameter for this body ?
52mm or perhaps 55mm? (front and rear)
Clawhammers is offline   Reply With Quote
Old 09-23-2014, 05:07 AM   #34
Chaz955i's Avatar
I built mine up on a SpeedMerchant Rev7 with a 10.5 on 1s. Right now I am using Enetti tires that are straight out of the box. Getting a proper ride height was a challenge due to the tall sidewalls but the tires look correct for the wheel opening. Had some electrical issues on the first run but when working correctly the body was very neutral and easy to drive despite the tall tires.
Chaz955i is offline   Reply With Quote
Old 09-23-2014, 06:34 AM   #35
GT12 tires out of the box are 48 rear, 46 front. I ordered 2 last night for my SupaStox. Sticking with the AMR for the Rev 8. The Contact tires have great traction and are the right width.
Old 09-23-2014, 08:08 AM   #36
Originally Posted by liljohn1064 View Post
GT12 tires out of the box are 54 rear, 48 front. I ordered 2 last night for my SupaStox. Sticking with the AMR for the Rev 8. The Contact tires have great traction and are the right width.
Thanks a lot
Old 11-07-2014, 10:22 AM   #37
Just finished the painting
It's 1 of the thickest body I've ever cut....
I believe this would have great durability
Btw this is mounted on Tamiya RM-01X
Old 11-07-2014, 11:11 AM   #38
Mostly done and cut for a GT12. Still need to mount the rear wing and add the decals.
Old 01-03-2015, 06:34 PM   #39
Regional Moderator
disaster999's Avatar
how does this body perform compare to a pan car body?
disaster999 is offline   Reply With Quote
Old 01-03-2015, 07:47 PM   #40
I ran it on asphalt, this body do not have enough frontal down force to steer the car into high speed corner @ 4.5t motor.
Xray X12 2015
ARC R10 ATS
Old 01-04-2015, 07:27 AM   #41
EricPF's Avatar
To be fair, the PFM wasn't designed for use on asphalt nor with mod motors. It was made specifically for GT12 racing, which is 13.5t 1S racing on carpet using foam tires.
Eric Epp
PROTOform // racepf.com
EricPF is offline   Reply With Quote
Old 01-05-2015, 11:27 AM   #42
And for GT12, this body is incredible.
