Old 08-19-2005, 01:52 PM   #1
Send a message via ICQ to Jan Larsen
Default Quick question about belts
Here's a quickie;
Can drive belts get sloppy after extended use? The car in question is a XXX4 4WD buggy. The problem is that whenever I touch the brake, it sounds like the belt is skipping. At hard braking it litteraly sounds like the thing is falling apart; I mean, there's HUGE skipping...I think.
I've had the entire drivetrain disassembled and noticed nothing wrong. The problem does not exist when on the throttle.
Perhaps someone has other ideas?
Jan Larsen is offline   Reply With Quote
Old 08-19-2005, 02:15 PM   #2
koabich's Avatar
Send a message via Yahoo to koabich
Over time belt will wear out...mostly stretch.
As far as belts skipping under braking, I thought that was a common thing with th XXX4. I don't think it's a problem, I just think it's normal for the belt to skip while under deacceleration on this car. Try tightning your belt or get a new one if it's bad.
Maybe some more familar with this car can help more.
koabich is offline   Reply With Quote
Old 08-19-2005, 03:43 PM   #3
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Skipping belt under braking is very common with that car. It sounds horrible under braking.
Jon Kerr is offline   Reply With Quote
Old 08-19-2005, 09:14 PM   #4
If you do Experience the belts skipping . It is normal .. But if your replacing your belts ,make sure to replace the pulleys also .. as they do tend to wear , and can cause new belts to wear faster ...
Mark Barden .
mb racer is offline   Reply With Quote
quick question pinggoy Chat Lounge 6 06-10-2008 10:58 AM
quick question Dirtfreak15 Painting, Designs, Graphics and Photography 9 07-05-2005 01:21 PM
a quick question benraldo the ho Electric On-Road 7 03-29-2004 10:46 AM
Quick question zachzachz Electric On-Road 2 08-25-2003 07:48 PM
Question for parking lot basher running belts... puma1824 Nitro On-Road 17 04-01-2003 05:30 PM
SEO by vBSEO 3.5.0
