Deans Speed Jig
Does anyone know if the new cells fit correctly in the Deans speed jig ? Hate to waste my money to find out... :)
The Speed jig works fine with all cells. It includes a foam spacer that can be compressed.
the new 37- 3800s fit but they are a little of but it will work
make sure you push all of the cells to the top or bottom of the jig before soldering :) This speed jig is definately worth getting, and for the price you cant go wrong..
The 3800's will fit but just barely with 6 cells...
I took out the foam peice and cut it in half and re-shoe goo'd it back in now it does 3700-3800 no problem...
Also if you plan on staying with the 3300 pack than do not do this modification as it will not hold those cells in tightly anymore... -Shookie <>< |
