Old 08-18-2005, 10:14 PM   #1
LosiSuperTruck's Avatar
Trader Rating: 18 (100%+)
Default Soldering Tips\Wire Type?
Hi All,
I am new to electric RC and have bought a used TC4 that is coming with some batteries and motors, none of which have wires attached.
I have limited experience with soldering, any tips for me? I have a really hard time soldering because it is hard for me to hold the iron, wire and solder all at the same time...there must be a trick to this as its hard to keep the wire in contact with the connector (ned three hands ).
For wire type, would it be ok to use "Primary Wire" seen here (http://www.powerwerx.com/product.asp?ProdID=3154), I noticed the strand count is considerably different, the primary wire has 19 strands where silicone wire that I took off an old battery had about 36 strands. Gs racing wire claims to have 665 strands (http://www.gsracing.com/web/page.asp...id=121&id=849). Does the strands matter? Does silicone matter? If I use primary automotive wire will I loose any power? It feels just as flexible as sillicone wire and a a fraction of the cost.
LosiSuperTruck is offline   Reply With Quote
Old 08-18-2005, 10:23 PM   #2
Originally Posted by LosiSuperTruck
(ned three hands ).
No, you need to buy a third hand
(At least that's what they are called over here).
It is a pair of small alligator clips on a stand which can hold the wire and the connector so you have 2 free hands for the solder and the iron.
They go for about $2,50 over here.
Can't tell you about the wire since I haven't seen it. But wire = wire mostly
If it's just as thick it will most likely be just as good.
vassago is offline   Reply With Quote
Old 08-18-2005, 10:47 PM   #3
newracer's Avatar
R/C Tech Charter Subscriber
To solder make sure eveything is clean and always tin all surfaces before you connect. Balak Racing has a good "how to" on soldering.
Wire isn't all that expensive, it is nice to have it as flexible as possible.
newracer is offline   Reply With Quote
Old 08-18-2005, 11:32 PM   #4
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
I know this is irrelevent but what connections are you using?
I couldn't tell you anything about silicon wire and to what effect the number of strands have but i use Dean's Wetnoodle with 1660 strands of wire.
Sean
Team Duratrax is offline   Reply With Quote
Old 08-19-2005, 02:18 AM   #5
Yes pick up a third hand tool. worth every penny. here a tip for you. when your done with your iron. clean it then apply a good coat of solder on the tip. this will keep your tip ready and fresh, and also prolong the life too. One of the guy's at my club is an electronic tech.(great to have he fixed my esc atom.) The wire I beleive the more stands the less resistance you will have. but being flexible is good too. Heck I could be wrong.
cyrrus is offline   Reply With Quote
Old 08-19-2005, 05:18 AM   #6
newracer, that is a nice tutorial
....I will be using Deans plugs. Anything I should know about using them?
Old 08-19-2005, 07:27 AM   #7
newracer's Avatar
you definitly need a third hand tool or mini vise to solder Deans plugs. Practice you soldering skills first, you need to be able to solder Deans quickly so they do not heat up too much and the pins move out of alignment.
Old 09-04-2005, 03:24 PM   #8
calstarjig90j's Avatar
Third hand tool definetly worth every penny. Here's one that I use to not only to help out with soldering but also as a third eye =). Gives some protection and to help see things a little clearer.
calstarjig90j is offline   Reply With Quote
Old 09-04-2005, 04:24 PM   #9
Easy solution here,put the plugs together when soldering wires to them.
Hyper1 is offline   Reply With Quote
Old 09-04-2005, 04:28 PM   #10
scoobydo's Avatar
Definitely a huge problem with deans plugs. If you keep the heat on too long the plastic will melt and move them out of alignment. You have to be quick with them.
scoobydo is offline   Reply With Quote
Soldering tips wolfman76 Australian Racing 4 09-15-2005 05:21 AM
soldering batterys with wire? kh15 Electric On-Road 9 01-16-2005 10:55 PM
Electrically&Soldering challenged ISO 3-wire ESC & connectors Q and Tips&Tricks Tom G Electric On-Road 4 06-26-2004 08:37 PM
wire type and size? djrfan Australian Racing 2 03-29-2004 04:14 PM
Soldering the red wire drx Rookie Zone 5 03-13-2004 03:13 PM
