Old 04-30-2014, 11:23 PM   #1
Default Tires for Autonmous 1/12 Pancar
Hello all,
I am building a autonomous line following robot using a 1/12 pancar (Tamiya RM-01- probably not the best choice). The original tires works fine, but I'd like to make it faster using real Pancar tires. I have taken care of all the mechanical modifications to get the tires on the car.
Here are the spec for the car and the racetrack:
Car weight distribution: 50/50 front and rear
Car weight: 800g~900g
Servo: 0.03sec/60deg
Computer control loop update rate: 200Hz
Carpet: Office carpet
Race Duration: 4 min max
Min corner arc diameter: 6'
Since the race duration is so short, should I just use the softest tires for both front and back? Which brand of tire should I get? What should I do to prepare the tire (since there's virtually no time to warm up the tire on the track).
Please let me know if additional variables are required to make the decision.
Here's a video of the car with Tamiya HBR tires on youtube:
mmx3se is offline   Reply With Quote
Old 05-02-2014, 07:10 PM   #2
Ulti tires. Search for it.
Prince Nuada is offline   Reply With Quote
Old 05-03-2014, 04:28 AM   #3
I)arkness's Avatar
if you are using the RM-01 then to fit normal 1/12 tires you will need the option front axles and bearings and remove the rear hex adapters. then you will fit any std rims available rather then using the tamiya stock
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
1/12, autonomous, line follower, pancar, robot
SEO by vBSEO 3.5.0
