Serpent S411 Eryx 3.0
#361
Great job Cody, thanks for representing.
#362
This weekend I attended the Swedish Nationals in the modified class. We are using Ride REX30 tires and the carpet track was fairly open and fast with pretty high grip. When the grip came up the car was very good and kept getting better as the race continued. I qualified 6th with two 4th places and one 5th place (round-by-round). Got taken out in the finals so couldnt finish better than 7th. I basically run one of Marc Fischers ETS setups and it works great. I m using VBC o-rings in the dampers with Tamiya bladders on top. All the rest is Serpent standard parts.
http://www.redrc.net/2015/02/swedish...rt/#more-92466
/Christian Holmström
#363
Are those bladders the greenish/teal colored ones? I think the clear Serpent ones work awesome. What made you use the Tamiya ones? Just curious
#364
Hi Cody, I can't speak for the bladders that Christian uses, but I use either the Tamiya black bladders or the Yokomo blue bladders. They are slightly a bit shallower (sp?) than the Serpent white bladders, but the real nice part about them are the lips. The profile of the lip is rounded instead of a square cut, so the aluminum upper clamp collar goes over the lip a lot easier than the stock ones.
I do have a question about your posted setups. Both of them, I see you don't run front arm sweep, just wondering why, and what handling characteristic you where looking for doing this? Thanks
#365
#366
#367
I find the shock action is fine with the serpent clear bladders it's just the shock collars are almost impossible to turn as the bladder doesn't bite the cap enough to hold it and it just free spins. I'm currently using the old serpent black bladders in 1 set of shocks and the Tamiya bladders in my other set. I drill my caps with a 1 mm drill bit for zero rebound. I've had best luck with the serpent clear bottom oring still. I do like the Kyosho xrings and the rsd orings which both require sone shimming. I've just received some of the rdrp orings from amain to build up my spare set with those as they were recommended by heaps of guys in the FB page.
My next query is the new dodge dart. Anyone run one yet? Got mine in the post today. Not sure how it's going to go but it sounds promising. Any feedback here?
#368
#372
Basically more steering to a point... I've tried it but personally didn't like the feel it gave in modified. Sure it gave more steering but I felt I lost some consistency and stability at the rear.
#374
It's early days I know but it looks like Victor has settled in with the new car pretty quickly by setting the fastest 3 lap time in the 1st round of practice at the ETS in Germany. Woot!
http://www.myrcm.ch/myrcm/report/en/18916/144130
#375
The car looks seriously hooked up with Viktor behind the wheel! I'm glued to Myrcm watching his debut unfold!
