Old 10-20-2014, 12:28 PM   #226
Thanks for your answer. But how do you for use them, it's quite a bit too long, no?
*LAF Painting*
february is offline   Reply With Quote
Old 10-20-2014, 12:50 PM   #227
chicky03's Avatar
Send a message via AIM to chicky03
Nice job David!
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 10-20-2014, 12:55 PM   #228
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by chicky03 View Post
Nice job David!
Thanks Paul! I wish you could have been at IIC.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 10-20-2014, 01:37 PM   #229
You need fornt arm from V2(with 2holes). And you can drive ride height about 5 mm with 63mm tires diameter.
DomenL is offline   Reply With Quote
Old 10-20-2014, 01:55 PM   #230
Johnny Wishbone's Avatar
Hi guys.
How are you able to use Yokomo spring with the Eryx 3.0?
Thanks.
If you want to run the Yokomo springs there are a couple of things to check to be able to use them. First off you should make sure you have the lower spring locators that where intended for the Serpent short shocks, these should be counter sunk so that the lower shock eyelet seats into the locator. I've seen some people with the original locators for the RCM/RCXX shocks and these sit too high and cause problems with longer springs and ride height issues. Also make sure you have the newer style spring adjusters. These are slightly different then the older ones as they have the top part of the adjuster opened up so if you screw them to the very top of the shock they will actually go up almost into the o-ring, which will give you about 1.5mm more length out of the shock as well. I know that when I use the Yokomo springs I can get the car to about 3.5mm ride height when the adjusters are all the way up, so this should give ample adjustment.
Another thing to watch out for on the car. If you try to run the rear shocks in the lowest setting on the shock tower, check the spring locators for clearance with the arm. I have had to space the lower shock mount out about 2.5 - 3mm on the arm so that the locator was free of the arm. Not sure if its a real issue, but I prefer to not have them touching.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-20-2014, 02:34 PM   #231
orcadigital's Avatar
Trader Rating: 61 (100%+)
Originally Posted by Johnny Wishbone View Post
My car comes in at 1380, but I have to run a 12 gram weight in the center to make weight. Thats with a fan and a 7200 SMC battery,(spool in the front).
Awesome. If they end up using it at the worlds I'm sure there will be more input on it. I forgot to mention the roll center and car width will be effected when going to the ARS setup, sorry. Looks like your on the right path to success with it.
Mike tried the RRS on Sunday (homegrown RRS with the links connected to the underside of the top deck) and did not notice much difference. I did not test it as our practice time was so limited and with the number of cars breaking (not necessarily Serpents), I did not have spare bits for it. I will try it more indoors, but I have heard such mixed information regarding even the assembly, I want some time to play with it before making any real recommendations.
Originally Posted by wwddww34 View Post
My first experience at racing in IIC is "in the books" and I must say that I have never been so impressed with a Touring Car chassis as I am with my Eryx 3.0. I spent 1 day practicing without the RRS in my car and I was getting laps in the low 12's (12.3 - 12.4 sec range). Then I installed the RRS and my car was so much easier to drive through the tightest corners. My laps improved by 0.8 secs! After 4 qualifiers I was sitting in 3rd place on the grid for the A-Main of Amateur TC. All of my friends in Dallas were surprised and (frankly speaking) so was I. The Eryx 3.0 is now legendary in my book. I was disappointed by fact that I was the only person with a Serpent car at IIC. However I had plenty of setup help from Paul Lemieux (who drives for Xray) and Manny Flores (who drives for Awesomatix). Tons of thanks to Paul and Manny for all the help.
Congratulations! That is a great accomplishment! I was just getting home and could not race 2 weeks straight or would have been there. Honestly Snowbirds is a bit in question as well, big races take a lot out of you.
How did you orient the c-hubs on the RRS? Did you use the RRS kit 2* hubs? What toe blocks did you run also?
Hi guys.
Thanks.
I have run the Yokomo springs but old style towers and shocks.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 10-20-2014, 03:00 PM   #232
Best to check, but I think if you run the link attachment to the bottom of the top deck you will get toe out on suspension compression, which isn't really what your looking for (or maybe you are).
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-20-2014, 03:04 PM   #233
wwddww34's Avatar
I used the 2 Caster hubs that came with the RRS kit. I oriented the C-hubs so that the top leaned toward the front of the car (opposite of how the front C-hubs are leaning). I used the 3.5 bracket and the 0.5 split brackets as shown in my setup notes below.
Old 10-20-2014, 03:06 PM   #234
I also think that with the exception of the wheelbase changing slightly between the available C-hubs in the back, it shouldn't make much of a difference as your only talking about around 2* of toe, which really isn't getting into the sweep part of the steering that would be effected by the castor of the c-hub.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-20-2014, 03:50 PM   #235
wwddww34's Avatar
Considering how Mike mounted the links to the underside of the top deck, there is no doubt that he would not see much difference. His RRS setup would be similar to mounting links on the inner hole of the RRS bracket and using 3mm shims on the pivotball height. This would yield a total difference of only 0.18 rear toe (see blue line in top chart of pic below). I chose to use the outer hole on the RRS bracket and a 1mm shim on the pivotball height which would yield a difference of nearly 1.0 rear toe when the car is in full tilt (see green line in bottom chart of pic below).
Old 10-20-2014, 03:52 PM   #236
cwoods34's Avatar
Thanks Gary! Yes I am David Walker
As far as the rest of my car's setup, I used Cody Woods' setup from his Southern Nationals race in September. See the attached JPEG sheet.
Glad it worked for you!
Did you make any changes as the event went on? I've mostly been swapping between 1.2 and 1.4 front swaybars and playing with the front shock position.
cwoods34 is offline   Reply With Quote
Old 10-20-2014, 03:56 PM   #237
wwddww34's Avatar
Yes. As the grip continued to grow stronger on the track I used 1.2mm swaybars on front and rear and I layed all 4 of my shocks down as far as possible. I also had to use CA glue on the sidewalls of my front tires to prevent traction roll all throughout the races. The Gravity RC GRC-130 tires had much more grip than the old Jaco Blues ever did.
Old 10-20-2014, 03:57 PM   #238
cwoods34's Avatar
I also had planned on IIC this year, but there was a strong chance my travel partner wasn't going to make it. Plus I can now hit both the Halloween Classic and Indoor Champs.
Definitely next year though
Old 10-20-2014, 03:59 PM   #239
cwoods34's Avatar
I thimk I have a spool indicated on the setup sheet. A front gear diff would've helped with the onthrottle/high speed traction roll issues. Also, how were you cleaning and doping the tires?
Old 10-20-2014, 04:10 PM   #240
wwddww34's Avatar
I used a front spool for the entire race. I avoided traction rolling by doping only 1/2 of my front tires. I was cleaning the front tires with motor spray after each run. Then 5 mins before my next run I would go to the Tire Doping Impound table and fully dope the rear tires and only dope the inside half of the front tires. I left the tires wet until 10 secs before my run, then I would wipe them with a rag and set the car on the track.
