Old 08-22-2014, 05:34 PM   #181
Trader Rating: 14 (94%+)
Originally Posted by Benzaah View Post
Droop is another tuning option I've been messing with. We start racing at 6pm and our track goes from warm to cold at night. Anyone's thought on changing droop to suit track conditions? More front vs rear? Less vs more? I like how sharp the car becomes the less droop I run but also really like how running a lot of droop can show off how the chassis flexes thru the corner. I tend to run a touch more droop front than rear. 5.8/6 fr ride height with 3/2.5 fr droop. What kind of droop settings are working for you?
Thanks in advance for any replies. Regards Benzaah.
I run 1.5F 2.0R droops. Others are very similar to yours or Orca's. Our track is low to medium traction with large sweeper and long straight away. Even with low traction, I find that less droops are better, especially at twisty sections of track (esses). There the car has to be fast (almost full throttle at 17.5T) to be competitive at our track and it's been better w/ less droops.
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 08-23-2014, 10:46 AM   #182
Trader Rating: 35 (100%+)
If anyone has one for sale please let me know
XRAY T4 15' MOD:X-RAY T4 15 17.5:T.O.P Rebel WGT:VBC LIGHTNING F1
5280 RACEWAY "Racing Elevated"
MILE HIGH INDOOR CHAMPS April 17-19th 2015 @ www.milehighindoorchamps.com
Losi22 is offline   Reply With Quote
Old 08-25-2014, 10:13 PM   #183
Phoenix82's Avatar
3.0 is on the way. Thanks to Paul and Desoto Racing
Nick k
Phoenix82 is offline   Reply With Quote
Old 08-26-2014, 05:12 AM   #184
dan_vector's Avatar
Trader Rating: 25 (100%+)
Thumbs up
Nick k
Great choice! You'll love the car
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-26-2014, 07:40 AM   #185
wwddww34's Avatar
Trader Rating: 9 (91%+)
I found one locally. This one, Serpent Eryx 3.0 FS, is still for sale.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 09-03-2014, 08:18 PM   #186
purple haze's Avatar
Which carbon chassis comes in the chinese version kit ?
thanks .
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 09-07-2014, 07:16 AM   #187
Selling my Serpent if anyone is interested.
Serpent 3.0 ERYX TC
Josh Hohnstein is offline   Reply With Quote
Old 09-11-2014, 06:50 PM   #188
Phoenix82's Avatar
Well got the car built. everything went super smooth. zero issues, will be running it this weekend. will check back..
Nick K
Desoto Racing|Novak|Airtronics
Old 09-12-2014, 07:44 AM   #189
wwddww34's Avatar
Nick K
Nick, will you be running on asphalt or carpet? Also are you using the RRS?
Old 09-12-2014, 11:33 AM   #190
Phoenix82's Avatar
I only run on carpet up here in the great white north. our local track is a small/tight layout. 25x50. I will be buying the RRS, Johnny ran a version of it a month or so ago, seemed to work really good.
Nick K
Old 09-17-2014, 11:57 AM   #191
Phoenix82's Avatar
Well. I got to run the car at our local club race, car was really good, i did have the mounting hardware for the servo loosen off. but car was good. i was running med links. 35/27.5 shock oils with blue/black yoko springs. Will report more tomorrow after practice tonight.
Nick K
Old 09-17-2014, 12:58 PM   #192
Hey guys feel like a real dummy for asking this but where are you mounting the belt tensioner?? Have the 3.0 version...any help or even a pic would be much appreciated.
Davv is offline   Reply With Quote
Old 09-17-2014, 01:39 PM   #193
Phoenix82's Avatar
I personally have never ran one. As long as your belt is adjusted correctly. should not be an issue.
Nick K
Old 09-17-2014, 03:04 PM   #194
On the top deck. A bit forward from mid point. You will see a hole on the deck. At the beginning, you might not need the tensioner but as the belt loosens up, you might need it (In response to Phoenix82's comment) if you run faster classes. W/ 17.5T class, I don't run tensioner. But since you have it, you might as well use it
Old 09-26-2014, 09:56 PM   #195
cwoods34's Avatar
Here's a setup I ended up with at the Southern Nats in Nashville last weekend. Qualified 4th, finished 3rd in the 17.5 A-main.
Gravity tires made a ton of grip, to the point that they would feel too gummy as the run went on. The car never wanted to traction roll, however. I ran 0 front camber so that I could drive the car as hard as needed given the grip level. On anything less than high bite or on other tires I'd start at least 1* camber.
The guys that have driven the car initially didn't like how much steering it had, but once you learn to be smooth with the steering input this setup can be really fast. I set full steering lock (knuckle to c-hub) at 100% dual-rate on the radio, and usually ran around 80%. I didn't get to test with an LTCR yet, but I always favor the Mazdaspeed 6.
A tight front gear diff worked well, too. Other things worth trying if you want the car to be a little more comfortable would be a 1.4 front swaybar, LTCR body, and fully long wheelbase.
The car only lacked a tad bit high-speed rotation, but was still comfortable to drive. An LTCR may fix that. It definitely made up for it in the infield.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
