thrust bearing
Old 08-17-2005, 06:32 AM
Fuzzy's Avatar
Default thrust bearing
I did a search and can't find an answer. Other than Slapmaster, does anyone else make a thrust bearing assembly for 1/12 scale?
Fuzzy is offline
Old 08-17-2005, 06:35 AM
1fastdude's Avatar
Trader Rating: 16 (100%+)
Thrust bearing??????? What type of diff do you have?
1fastdude is offline
Old 08-17-2005, 06:42 AM
rayhuang's Avatar
Fuzzy-I'll measure mine and see what I come up with for size. I can order you the Slapmaster thrust assy antime. Between that and ceramic diff balls-unless someone roaches your spur-you wont worry about rebuilding your diff for a long time. MInes been built for months-even mod and some nasty tank slappers-still smooth as butter.
rayhuang is offline
Old 08-17-2005, 06:51 AM
Fuzzy's Avatar
Ray,
I have the Slapmaster thrust ass'y on my car now and it works great. I was just wondering if there was another out there that may be a little cheaper.
Fuzzy is offline
Old 08-17-2005, 06:52 AM
Fuzzy's Avatar
CRC large-d ring diff on a T-Fource.
Fuzzy is offline
Old 08-17-2005, 06:55 AM
vtl1180ny's Avatar
Do a search in the 1/12th forum, I posted the parts you need....
vtl1180ny is offline
