Old 08-13-2005, 10:35 AM   #1
DustinR's Avatar
Default Gearing for Dummies. [HELP]
OK I have a HPI Pro 2 and a Losi XXX-S G+. I am wanting to get the final rollout on both of the cars to 112-115. Can anyone help me.
On my XXX-S I am running a 128 64 pitch spur.
On my Pro 2 I am running a 87 48 pitch spur.
I am running rubber tires that are 63mm in diamiter on both cars. I do not know the internal ratios of either car.
I do not want just an answer like run a 28 pinion altough that is also needed. I would like someone to explain how they came to their answer.
Thanks so much for any and all help. I plan to race these cars tomorrow.
Grandview Hobbies, HobbyWing, J-Concepts, Airtronics, LukeDawg Graphics, TQ Wire
DustinR is offline   Reply With Quote
Old 08-13-2005, 10:47 AM   #2
try here www.gearchart.com ... you can calulate roll out youll need but you will need to enter your final for both cars as well ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 08-13-2005, 11:04 AM   #3
Rob Phillips's Avatar
You will need the following info to figure out your FDR or rollout
-what class/motor
-what is the track size
-is it tight or open layout
When I used to run a xxx-s on carpet w/foams I ran something like a 33/128 for stock. your tires ar a little bigger than my foams so you would proably want to gear it something like a 31 tooth pinion. this was on a tight layout and about a 90 foot straight.
use gearchart.com to find the internal ratio's and compute your rollout. I think you should be able to find out what to run when you get to the track. Just ask one of the fast guys, they should be able to help you or point you in the right direction.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-13-2005, 12:27 PM   #4
DustinR's Avatar
Ok, But now I have a question. I went to www.gearchart.com and entered the gearing. Worked cool but I wonder about the pitch. I run 64 pitch in xxxs and 48 pitch in pro 2. When I enter it in the chart I do not see a difference. Does someone have an idea of how to combat this.
Old 08-13-2005, 12:47 PM   #5
There is no difference, Final Drive Ratio is the same regardless of 64 or 48 pitch. Only difference is the drive ratio of the transmission.
pops is offline   Reply With Quote
Old 08-13-2005, 02:10 PM   #6
just enter the info. and your done .. as said before there's no diffrence and gear charts program will have you dialed in ... 64 or 48 pitch ..
Mark Barden .
Set ups for Dummies sosidge Electric On-Road 2 11-21-2007 09:54 AM
tc4 for dummies bignotch Rookie Zone 2 01-25-2006 03:07 PM
painting for dummies pigpen22 Painting, Designs, Graphics and Photography 5 12-29-2004 05:18 AM
gearing for dummies pls help cox Electric On-Road 5 08-27-2003 08:16 PM
Painting for Dummies Round_Guy Painting, Designs, Graphics and Photography 2 07-13-2003 10:34 AM
