Like Tree11Likes
Old 12-17-2015, 02:50 PM   #1471
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by OSherman View Post
Take the time and figure out its quirks and make it better.
That's what Exotek did....j/k
Old 12-17-2015, 03:04 PM   #1472
Leester's Avatar
Trader Rating: 21 (96%+)
Wasn't going to go there....
Leester is offline   Reply With Quote
Old 12-17-2015, 03:31 PM   #1473
Leester's Avatar
[QUOTE=OSherman;14310676]Im not arguing the fact... my only point is that the lateral motor is what makes it an EVO6. Such as the TBO4.
As well as the AMC Pacer, Gremlin, Edsel and the Aztec.... all probably looked good on paper to someone, just not the consuming public.
Old 12-18-2015, 06:32 AM   #1474
theproffesor's Avatar
Trader Rating: 56 (100%+)
Anyone running the carbon main shaft? Notice any difference?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-18-2015, 06:55 AM   #1475
The difference per lap will be very slight, but over a six minute main it can lead to seconds off with the lower CG, and higher end of the run voltage, etc....
bertrandsv87 is offline   Reply With Quote
Old 12-18-2015, 07:14 AM   #1476
Ok now for the guys who actually race and own an EVO 6
Old 12-18-2015, 07:16 AM   #1477
I run the Ewippler carbon main shaft. It is noticeably lighter than the aluminum shaft. I can say that I don't "feel" a difference in the car but as a matter of principle I always try to run the lightest possible rotating mass. I'm happy with the carbon shaft will be getting one for my newly acquired black edition evo 6 as well!
I'd like to try the Exotek lightened outdrives, does anyone run them? I center-drilled out a set of outdrives on my VBC and shattered one on my first run. I'm sure Exotek has a better method than I used.
I also drill 5 small holes in the aluminum wheel hex's for weight savings. Again, I know it seems silly, but everything I can do to lighten rotating mass is a win in my book.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 12-18-2015, 07:21 AM   #1478
Professor - I think I remember a post from you a while back (maybe even in response to one of my questions) regarding someone you used for anodizing aluminum. I want to have a few of the blue Exotek parts anodized black so my entire black edition is truly black. Can you send me info on the place you used and did you have to strip the original anodizing or did they strip it and re-anodize it?
Old 12-18-2015, 08:13 AM   #1479
OSherman's Avatar
im running the WipplerStick on my EVO6... finally got the drivetrain, shimmed, sorted and smooth. (i think)
will try both the stock shaft and WipplerStick back to back for comparisons sake... there is a difference on the scale which is difference enough for me.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 12-18-2015, 11:58 AM   #1480
Leester's Avatar
Anyone running the carbon main shaft? Notice any difference? Ok now for the guys who actually race and own an EVO 6
Professor, not sure what you've done to lighten the drive train so far but the Wippler carbon shaft will definitely help. Some of the things that I've done to my EXO6 so far can be found on posts 1156 and 1187. I use either the Exotek or R1 Wurks lightened axles in the rear (can't in the front because I use DCJ's), the TB03 ball diff, a spool up front and Wippler's carbon drive shaft. The combination of all of these things make a big difference in on power forward traction and rotation. Watch the video of my car in post 1187. Notice the gap that I was able to pull on the car in second in just a couple of laps. This was on asphalt. Should be even better on carpet with smaller track and more turns.
Old 12-18-2015, 12:17 PM   #1481
I am going to keep my gear diff in the rear. I run the plastic gears, so that's a weight savings there. From what I hear the EXO/r1 axles are a good way to lighten the drivetrain, but not a great idea if you attend a lot of board meetings... I run a spool up front, and just purchased the lightweight TA05 direct drive outdrives and a couple of ewipplers drive shafts. I should drop a few grams off the drivetrain.
Old 12-18-2015, 12:41 PM   #1482
Leester's Avatar
Gear diff (with plastic gears) vs ball diff 11-12 grams. R1 wurks lightened axles are made from Swiss steel w/ bored out axle similar to Xray's. Doubt if they will break with a "board meeting". The other option is the Exotek lightened out drives made from 7075 aluminum. If your talking about the plastic out drives for the spool, I wouldn't run them without the aluminum covers that slides over the top of them. If you're worried about "board meetings" I wouldn't run them on carpet at all, just too fragile. Cost me a shot at winning the ROAR Onroad Paved Nat's in GT10 last Fall while battling with Rod Canare. Got caught up in with a back marker during the race and broke the plastic outdrive. Ended my race. I've switched to the steel since then.
Old 12-18-2015, 12:54 PM   #1483
The ones I ordered looked like metal with cut outs
Old 12-18-2015, 02:03 PM   #1484
rtypec's Avatar
I am actually in the process of cleaning and shelf-queening the winning GT10 car and took a picture of my front gear box with lightweight goodies. I also ran Square titanium axles. They cost bank but are extremely durable and aren't so exposed that they fling grease everywhere.
rtypec is offline   Reply With Quote
Old 12-18-2015, 02:40 PM   #1485
Aitutaki's Avatar
hi guys, enclosed a little different carpet setup of my exo-6
had some problems with grip rolls, and went wider in the front and changed the suspension mount spacer.
After getting help and tips from a nice tamiya buddy, i managed to finish in 3rd position.
Aitutaki is offline   Reply With Quote
