Like Tree11Likes
Old 11-04-2015, 10:45 AM   #1276
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Leester View Post
Carbon around 80, aluminum around 105 grams.
That's not bad at all considering other car brands aluminum chassis adds a whole lot of weight. Some titanium screws can help reduce the weight difference here.
Josh-n-ya is offline   Reply With Quote
Old 11-04-2015, 01:41 PM   #1277
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by RedBullFiXX View Post
The USGT tires are good to go
Similar to Sorex 32 & Jaco spec
I'm a bit shocked they work as well as they do tbh
Cheap and they last pretty long too, what's not to like?
Old 11-04-2015, 01:47 PM   #1278
robk's Avatar
Spy Pix of prototype EXO6 aluminum chassis soon to be released Carpet guys you're going to WANT this! The chassis will be stiffer than the cf chassis and should be the ticket on medium to high grip carpet surfaces. Fit and finish is the same high quality you've come to expect from Exotek. Just in time for Santa!!
Very excited about this. At the Halloween Classic, I experienced what Redbull described in an earlier post, just too stuck no matter what I did (wholesale changes!!). Having seen the car on asphalt, it is a killer with the graphite chassis. Should be just as dialed on carpet with the aluminum.
Old 11-04-2015, 02:27 PM   #1279
Josh-n-ya's Avatar
When they say measure from top of axle to setup board for your droop measurements. Top of what axle? Where?
Old 11-04-2015, 02:33 PM   #1280
Josh-n-ya's Avatar
Oh and what gear combo's are people using with 21.5?
Old 11-04-2015, 02:38 PM   #1281
Leester's Avatar
Trader Rating: 21 (96%+)
Top of wheel axle. Tires removed. Measure with the back end of your calipers - the part that the little tail extends out as you are opening up the caliper. Stand caliper up vertical, push little tail down on the set up board until the back side of the caliper touches the top of the wheel axle.
Leester is offline   Reply With Quote
Old 11-04-2015, 03:05 PM   #1282
Trader Rating: 28 (100%+)
https://www.tamiyausa.com/articles/f...3#.VjqPIqTPY0I
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 11-04-2015, 06:54 PM   #1283
theproffesor's Avatar
Trader Rating: 56 (100%+)
Even with the few extra grams of the aluminum, it should be a problem. I originally thought these cars were a bit heavy, but after I put a couple new bodies on that weren't covered in duct tape on the inside, they both came in about 30 grams under weight for their respective class.
The 17.5 has 5000mah SMC batt and the USGT has a 6500 SMC.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 11-05-2015, 02:20 PM   #1284
racer x 1's Avatar
Trader Rating: 27 (100%+)
What springs is everyone running on med bite carpet, Tq raceway?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-05-2015, 02:57 PM   #1285
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
In carpet I raised the rear roll centers 1mm . Did you try that ?
King of B Main is offline   Reply With Quote
Old 11-05-2015, 03:00 PM   #1286
Matt , it all depends how traction is and what oil you are running . Most people are running yokomo springs. Last week I ran blue front blk rear . I also have ran yellow , yellow , pink , blue
Old 11-05-2015, 03:56 PM   #1287
robk's Avatar
You mean besides front and rear hinge pin width, wheelbase, shock position, spring choice, shock oil, rear diff oil, camber link height/position, droop...?
LOL
Yeah, I tried a few different settings, coming to .5mm front and rear. I had looked at the setup sheets for Rod C and Lee P from the nationals just to get an idea of what they were doing (in fact I started at home with Rod's setup). Not that it necessarily translates, but its good to see where fast guys are going in general. The biggest change was putting my Xray back together which moved me up 2 mains. That was a desperation move but it did kind of confirm my thoughts that the chassis was a little flexible for the amount of bite at the race. The fact that the car was good at home on a lower bite surface makes me think it's probably going to be good again on higher bite with the metal chassis.
Old 11-05-2015, 05:49 PM   #1288
LOL
Yeah the traction at the Nats was low bite .
Old 11-06-2015, 09:16 AM   #1289
Aitutaki's Avatar
hi guys,
anybody of you tried the Hiro Seiko Titanium screws ?
are they ok?
http://www.hiro-seiko.com/news.php?action=detail&id=109
will save about 25g ...
Aitutaki is offline   Reply With Quote
Old 11-06-2015, 09:58 AM   #1290
lbckevin's Avatar
Trader Rating: 89 (99%+)
I am using them and they are nice. I did not get a complete set, just pieced it together. I got them from Pit box Hobbies.
http://www.pitboxhobbies.com/screws.htm
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
