Like Tree11Likes
Old 10-26-2015, 07:02 AM   #1216
theproffesor's Avatar
Trader Rating: 56 (100%+)
Mine is whisper quiet. I am running the plastic diff gears (sanded). And I shimmed the ring and pinion gears (diff input and main diff gears) front and rear so there is just a tick of play.
I am also running the EXO conversion and never ran it with the transvers motor.
I love the sound of a shaft drive over a belt drive. And this thing brakes extremely hard. Had to turn turn down my initial brake setting on my speedo.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-26-2015, 07:22 AM   #1217
Emaculant's Avatar
Originally Posted by Johnn27 View Post
Are you running metal diff gears ?
Yes.
Originally Posted by vivo quevas View Post
If your drive train is noisy you have damaged the ring or the pinion gear one is missing a tooth most likely. You may need shim the pinion out or shim the crown gear. Mine was noisy and that was the problem when ever I here a noise that is what I check for
What ring? Which pinion?
I have the EXO conversion but I'm running it stock with the transverse motor mount for now. What size shims on what part of the pinion?
Emaculant is offline   Reply With Quote
Old 10-26-2015, 09:57 AM   #1218
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Emaculant View Post
Yes.
On the shaft the pinion is mounted to also the diff shims they are in your kit the ring and Pinion need the slightest amount of lash.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-26-2015, 11:09 AM   #1219
Originally Posted by Josh-n-ya View Post
Dave..what diff oil where you using? How was the feel?
A noob Jerez. Do you mean the diff oil to be filled up in the differential gear during setup? In the Evo 6 set up manual's supplement, it states that damper oil (clear) provided shall be used instead of differential oil, and I did accordingly. Am I wrong in this case? Thank you.
Kakaru is offline   Reply With Quote
Old 10-26-2015, 11:14 AM   #1220
You can buy aftermarket diff fluids. I use 1k-2k in my cars.
Old 10-26-2015, 11:24 AM   #1221
Emaculant's Avatar
Are you guys adding any shims or are you using just what came with the kit? Can you send me a pic?
Old 10-26-2015, 11:57 AM   #1222
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Inline Exo here
Used some shims with kit, not all
Steel diff gears 5k
Sounds same as belt drive
Old 10-26-2015, 02:02 PM   #1223
Michael@USPN's Avatar
Originally Posted by RedBullFiXX View Post
Inline Exo here
Steel diff gears 5k
Post a picture for all to see please
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 10-26-2015, 08:37 PM   #1224
Well, the thing is I'm following the Evo 6 setup manual to use the stock clear damper oil to fill up my differential gear. Am I doing the right thing? Do I need to buy differential oil and rebuild my differential gear? I'm a noob in RC and this is my first time building a RC car.
Old 10-26-2015, 10:18 PM   #1225
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
You did fine. Different thickness of diff fluid make the car act differently. I'm not sure what the thickness of the stock diff fluid is so I start with what most people start with and that's usually 2k. Haven't ran the car yet to decide what else to use yet.
Josh-n-ya is offline   Reply With Quote
Old 10-26-2015, 10:39 PM   #1226
Thanks Josh. Glad that I am not in the wrong track of build the Evo 6 thus far. :-)
Old 10-27-2015, 12:08 AM   #1227
Default Exo Six missing part
Hi just wondering if anyone elses EXO Six conversion kit was missing any parts.
Mine arrived the other day missing the Alloy motor mount, have sent an email today so hoping for a reply tomorrow
Tamiya Evo 6 Exoteck, Associated TC4 FT, Tekin, D4 13.5
Toolmannz2 is offline   Reply With Quote
Old 10-27-2015, 02:53 AM   #1228
Aitutaki's Avatar
i was missing a m2x4 screw... luckily not the alloy motor mount..
a screw is easy to replace
and of course the ball bearing, which is missing in every kit...
Aitutaki is offline   Reply With Quote
Old 10-27-2015, 06:58 AM   #1229
Josh-n-ya's Avatar
When I ordered from Exotek yeah my motor mount was missing. Sent them a email and they said they had realized there mistake and it was shipped shortly after my kit was sent. Got it in the mail the next day. Good service!
Old 10-27-2015, 07:08 AM   #1230
I had my first outing on the track with the Exo conversion a few days ago and it handled great. However, after five runs or so, I did notice the gold drive cup from the spur gear was starting to open up slightly. Not as wide as Aitutuki's but I am starting to get a little play between the cup and the plastic cap. Was there an error in my assembly or is this a known problem with the drive cup?
speed_dmon is offline   Reply With Quote
