Like Tree24Likes
Old 10-21-2015, 01:24 PM   #1201
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Is 450cst typical shock oil for these smaller shocks on this car? Any special setups for carpet on Exo6?
Josh-n-ya is offline   Reply With Quote
Old 10-21-2015, 01:47 PM   #1202
JD Skyline's Avatar
Today my TB EVO 6 Black version arrived!! Me sooooo happy. hahaha! Will be a big change after driving a TB03 for several years!
Need to start building it and maybe order the exotek conversion!! This will be my competition car for next year!! So need to keep up with this thread after reading it back and forth!
JD Skyline
"NO GUTS NO GLORY"
Tamiya TRF418, Tamiya TT-01 Type E and Still lookin'for more Tamiya cars.......
http://jdskyline.blogspot.com/
JD Skyline is offline   Reply With Quote
Old 10-21-2015, 06:26 PM   #1203
theproffesor's Avatar
Trader Rating: 57 (100%+)
I've got two set ups going right now. One for USGT and one for 17.5. I'll get them up in the morning. They are both works in progress, but they are great starting points. Stable and allows the car to go where you want it when you want it.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-21-2015, 07:26 PM   #1204
Josh-n-ya's Avatar
Thanks!
Old 10-22-2015, 03:25 AM   #1205
I started both cars with this set up. Didn't touch the USGT car all day since it was working so well. Was having violent snap rolls with 17.5 and fought it half the day until I switched from sweeps to Jaco Blues. After that car handled very well with the changes that had been made.
Starting set up. For USGT
Shock positions fr-4. R-5
For 17.5 changes Dodge Dart body
76 spur 47 pinion
Front shocks RSD blue
1mm spacers under front pivot blocks
0 spacers under rear
1mm spacers on inner Ackerman steering linkage
3k diff fluid
Old 10-22-2015, 11:12 AM   #1206
Leester's Avatar
Trader Rating: 21 (96%+)
you are using the 39t gears? or the 40? as the tb04 diff gear has 3/32 diff balls for the Tamiya diff
TB03/EVO5gears.
Leester is offline   Reply With Quote
Old 10-24-2015, 12:02 PM   #1207
Josh-n-ya's Avatar
Thanks theproffesor, I will try that. What split blocks are needed for I
the inner front and rear pivot blocks? I might need the extra flex when racing on asphalt.
Old 10-24-2015, 04:46 PM   #1208
Are you running the EXO 6 conversion. If so, I wouldn't really worry about spilt blocks in the rear, the motor mount is so close, I don't think it would make a difference.
Those set-ups are for carpet, not asphalt. There is a good asphalt set up on the exotek site.
Old 10-24-2015, 05:25 PM   #1209
Am just got both my cars hooked up with the TA05 front C hubs. I won't get a chance to run them on the track until November, but I like them better than stock already. The are a little snug, but have ZERO slop. The stock C hubs had a tremendous amount of play in then from the top hat bushings. Hopefully the TA06 hubs hold up to my driving skills. If not, the next step would be some modded X-Ray hubs.
Old 10-24-2015, 08:19 PM   #1210
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
The more larger hole C-hubs meant for the DCJ have a lot of slop. Seems Tamiya still has not fixed this. The 418 had the older style C-hubs (same as TA05 molded ones with smaller opening), and they are a lot less sloppy.
Dan is offline   Reply With Quote
Old 10-24-2015, 08:47 PM   #1211
rc_square24's Avatar
Yes for some reason the DCJ chubs use different diameter king pin collars (4.5/4.6). The bottom hole has tighter tolerances but the top hole has noticeable slop. I just lined the hole with some CA glue to remove some of the play.
rc_square24 is offline   Reply With Quote
Old 10-25-2015, 01:24 AM   #1212
JD Skyline's Avatar
Ordered the exotek conversion kit, hopefully it will arrive this week....
There will be two tb evo6 chassis racing at our local club and both with a conversion kit from exotek haha... The competition will be killing the next season....
Old 10-26-2015, 05:31 AM   #1213
Emaculant's Avatar
How loud are you guys drive train? Mine is pretty loud compared to an Awesomatix. What can you do to make it quieter?
Emaculant is offline   Reply With Quote
Old 10-26-2015, 06:32 AM   #1214
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default Noisy gears
Are you running metal diff gears ?
Johnn27 is offline   Reply With Quote
Old 10-26-2015, 06:47 AM   #1215
vivo quevas's Avatar
Trader Rating: 18 (100%+)
If your drive train is noisy you have damaged the ring or the pinion gear one is missing a tooth most likely. You may need shim the pinion out or shim the crown gear. Mine was noisy and that was the problem when ever I here a noise that is what I check for
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
