Like Tree11Likes
Old 10-20-2015, 12:22 PM   #1186
snopro31's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Leester View Post
TB04 ball diff is 54522 and has all of the parts in a set.
does anyone know of a good thrust bearing for this diff, I built mine and it just always seems like it is gritty right from a new build
snopro31 is offline   Reply With Quote
Old 10-20-2015, 01:41 PM   #1187
Leester's Avatar
Trader Rating: 21 (96%+)
Here's a TOP 2x6 thrust bearing with ceramic balls that should help the gritty feeling. T.O.P. Racing (PO-PTB602C). TQ usually has them in stock but they are out of stock now.
Attachment 1324319
I'm using the Tamiya thrust bearing and 3mm steel balls right now and I agree that the diff has the gritty feeling you describe even when packed with Associated Black grease as thickly as I could get it in. I've got a bunch of time on the diff though and the grittiness hasn't gotten any worse. It hasn't affected performance though https://youtu.be/SmhEgHJtItQ?t=108
On power forward bite is crazy with the EXO6 The guy in second following me took third at the ROAR Nat's in GT10. He's driving an Xray T4 belt car
Leester is offline   Reply With Quote
Old 10-20-2015, 03:21 PM   #1188
When you say forward bit you mean steering of pulling out of a turn ? Is the rear hooked up good? Gear diff in rear what are you using up front
Huskerfan1212 is offline   Reply With Quote
Old 10-20-2015, 03:33 PM   #1189
snopro31's Avatar
are you changing the stock diff screw out with that thrust bearing? I am assuming that's a normal sized 620 thrust bearing and if so everyone I have found the stock slot head diff screw is to big for any 620 thrust bearing I have aka Tamiya 49300
Old 10-20-2015, 08:20 PM   #1190
Johnn27's Avatar
Trader Rating: 69 (100%+)
Questions?? Evo 5 ring gear on spool
If I decide to use the 51522 ring gear on the front spool do I need another pinion gear or is the Evo5 pinion gear the same as on the evo6/TB04 ?
Johnn27 is offline   Reply With Quote
Old 10-20-2015, 08:21 PM   #1191
Johnn27's Avatar
DBL Post
Old 10-20-2015, 08:28 PM   #1192
MikeR's Avatar
Trader Rating: 15 (100%+)
Forward bite means forward traction when pulling the throttle, whether turning or going straight.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-20-2015, 11:48 PM   #1193
Leester's Avatar
The ring and pinion gear (51522) comes as a set. Just use the pinion gear that comes with set.
Old 10-21-2015, 12:09 AM   #1194
Leester's Avatar
What he said.... couldn't have put it better myself. Thanks Mike! You can also see how much off power corner speed the chassis carries through turns. All (or most) of the space put on another car was in the infield. Pretty even with most of the field down the straight. I geared the car to take advantage of the EXO 6s infield edge. The car also brakes very well with the lightened drive train we talked about in an earlier post...This all adds up to a very driveable car. You can put it anywhere when you need to get up on the wheel to pass or defend.
Old 10-21-2015, 12:24 AM   #1195
Leester's Avatar
If you look at my earlier post 1187, I was offering this as a possible fix to you for a gritty feeling diff. The ceramic balls should do a better job of making the diff action feel a lot smoother. I haven't tried this bearing yet myself, but intend to when it is back in stock at TQ. I'll let you know then if the diff screw needs to be changed. Been running Tamiya stuff so long that I've accumulated every diff screw they've made
Old 10-21-2015, 04:13 AM   #1196
Never had that problem with the tamiya thrust bearing. Are you motor spraying the bearing then putting the aw grease in it?
Juan Aveytia is offline   Reply With Quote
Old 10-21-2015, 10:01 AM   #1197
snopro31's Avatar
ya I assumed you had tried it my bad, I have the Tamiya 620 the old style diff screw would fit not the large tb04 screw. a little unsure if the thin screw would have any effect on the diff not a straight pull to tighten type thing.
Old 10-21-2015, 10:10 AM   #1198
snopro31's Avatar
yes I cleaned it all before building it. the stock thrust is not a one piece bearing but I clean all the little balls and plates. just hoping someone else built this diff with either the stock thrust or found a good thrust bearing and if they had to do anything to make it feel smooth.
Old 10-21-2015, 10:45 AM   #1199
Trader Rating: 8 (90%+)
What's the difference between the TB04 vs TB03 ball diff (other than the gears)?
TenzoR is offline   Reply With Quote
Old 10-21-2015, 10:57 AM   #1200
snopro31's Avatar
you are using the 39t gears? or the 40? as the tb04 diff gear has 3/32 diff balls for the Tamiya diff
