Like Tree23Likes
Old 10-16-2015, 11:58 AM   #1156
Leester's Avatar
Trader Rating: 21 (96%+)
Dave,
Like the silver parts you've stripped. What mag cleaner did you use? Think I'm going to do the same.
Have you got Eric Wippler's carbon drive shaft yet? The drive shaft, Exotek's or R1's lightened out drives in the rear really give this chassis a ton of forward bite out of the corner. Both of these items combined will save you 10-12 grams in the drive train. If your going to run 17.5T, try theTB03 aluminum ball diff (54056) too. It holds up great as far as rebuilding with a 17.5T. Another large weight savings in the drive train over the Tamiya gear diff. If you want to stay with a gear diff, try the Spec R (SPR009-TB) Sean @ TQ has both diffs in stock.
Tamiya gear diff - 25 grams
Spec-R gear diff - 19 grams
TB03 Ball Diff - 14 grams
Lee
Leester is offline   Reply With Quote
Old 10-16-2015, 12:59 PM   #1157
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Leester View Post
Dave,
Lee
Feel like the new kid in school here
Tamiya & shafties
Guess I dove into the deep end
Thanks for the tips
Any mag wheel cleaner for "non clear coated" wheels will do
Should only take a few minutes, don't leave it in any longer than necessary
Recommend placing a bearing in the mount while soaking to keep tolerance the same
Rinse with water when blue is gone
Old 10-16-2015, 01:37 PM   #1158
Hi guys,
This is my first time building a Tamiya and shaft touring car, and when I started building my Tamiya Evo 6 (stuck at Bag A), I realized that the required metal shims (particularly 5x10x0.1mm and 5x10x0.3mm which will be used in many different parts of the car) are insufficient in Bag A (as indicated in the setup manual). I couldn't find these metal shims in other bags too.
Can you all please advise me as I'm a noob in Tamiya type car and shaft type. Thank you.
Kakaru is offline   Reply With Quote
Old 10-16-2015, 01:41 PM   #1159
Ivan Dickson's Avatar
Trader Rating: 11 (92%+)
Originally Posted by Kakaru View Post
Hi guys,
You may have to just buy some shims from your LHS. That's what I did.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 10-16-2015, 02:17 PM   #1160
Hi Ivan,
Thanks for your prompt reply. So it is normal that Tamiya shortchange small parts like metal shims in its out of the box car kit?
I bought the black version at a discounted price of USD$290 in my LHS, as they are shifting out of the location and having a last new one.
Do you think it is a good car as touring car usually are belt type due to the imbalance swinging and couldn't run straight?
Also, is TB Evo 6 part of the TRF family and does it consider as a pro kit?
Thank you.
Old 10-16-2015, 02:34 PM   #1161
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Dave,
Lee
so much to learn
madjack is offline   Reply With Quote
Old 10-16-2015, 03:07 PM   #1162
Hi Ivan,
Thank you.
It is a Pro level kit for stock classes
Every bit as fast as a TRF, if not faster
TRF belt cars are a more obvious choice for mod where efficiency is not an issue
Old 10-16-2015, 05:54 PM   #1163
Hi Ivan,
Thank you.
I won't say short change, most all parts are in the kit, I have 419 and EVO 6
and very happy with both kits, I just needed few extra shims...everyone who
I know that has built a quality Pro kit all have extra shims in there tool
case...I just need more at the time. My advice always keep a few extra
shims in your tool case.
Old 10-16-2015, 07:39 PM   #1164
Michael@USPN's Avatar
Dave,
Lee
Where can we purchase this drive shaft? Link please
Just found it. Thanx
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 10-16-2015, 09:16 PM   #1165
I see. Thanks Ivan and RedBull. :-)
Old 10-18-2015, 12:38 PM   #1166
Had a chance to run the new evil-six around our carpet track yesterday
With very little tuning it was quick and fun to drive
Used Yokomo Pink Front, Blue Rear springs
Pos 8 on shock towers Fr & Rr
450 cst
Car was surprisingly quiet too, sounded like a belt car, steel diff gears and all
Needs some tidying up before next outing
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-18-2015, 01:49 PM   #1167
Aitutaki's Avatar
450 cst
sounds great.
can you tell me the part numbers of the yokomo springs?
thanks!
Aitutaki is offline   Reply With Quote
Old 10-19-2015, 06:48 AM   #1168
Originally Posted by Aitutaki View Post
sounds great.
thanks!
http://www.tqrcracing.com/shop/produ....asp?p_id=8394
http://www.tqrcracing.com/shop/produ....asp?p_id=8411
Old 10-19-2015, 09:27 AM   #1169
Aitutaki's Avatar
thank you!
but i am just wondering why the original springs seems to be that bad to be needed exchanged...
nevertheless i'm gonna ordering some kokomo springs..
Old 10-19-2015, 10:45 AM   #1170
thank you!
Tamiya springs may be the best option
Just wanted to start with what I had for comparison to the Yokomo cars I normally run
Next outing will try Tamiya springs
