Like Tree24Likes
Old 10-11-2015, 07:19 PM   #1126
Default Exotek evo six chassis conversion
Exotek evo six chassis conversion back in stock limited quantity according to email sent
Toolmannz2 is offline   Reply With Quote
Old 10-11-2015, 10:31 PM   #1127
Simmi's Avatar
Originally Posted by theproffesor View Post
What's the part numbers on the 417 parts or the non carbon reinforced parts?
Hi, use TA05 C-Hubs.
I drive with them on carpet and outdoor this season and no one brake
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 10-12-2015, 07:24 PM   #1128
theproffesor's Avatar
Trader Rating: 57 (100%+)
So after my weekend of breaking glass c hubs (thanks for the info guys, going with the TA05 hubs). I found a couple setups that are pretty stable starting points for me on medium grip carpet. As soon as I get some blank set-up sheets copied and get my USGT and 17.5 set-ups on paper, I'll load them up here, and if I can figure it out on Petite RC.
The set-ups need some refinement, but the cars are really drivable with only a slight on power push mid corner and the rear just a little squirrelly on corner entry.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-13-2015, 09:02 AM   #1129
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Part number? I just bought a set of reinforced evo6 hubs. Are those going to hold up or shatter?😁
Is this with the exotech conversion?
What is the fdr ratio with the conversion? Anyone?
Josh-n-ya is offline   Reply With Quote
Old 10-13-2015, 09:16 AM   #1130
CL
CL's Avatar
Trader Rating: 32 (100%+)
Click on the link for TA05 part #.
CL is offline   Reply With Quote
Old 10-13-2015, 11:33 AM   #1131
Stock EVO hubs are very brittle. If you don't touch the pipes, then you are golden.
Old 10-13-2015, 09:54 PM   #1132
Michael@USPN's Avatar
Congrats to all the work and wins Mike and Lee have earned on this conversion kit. Much respect
Im looking to get two kits myself as I'm coming out of retirement lol. But I'm looking to get a blue original tb evo kit too. So one black (as i see that's all that it there right now) and the blue one. If you happen to have a blue tb evo 6 kit please pm me or if you know of one too please. Much appreciated
Looking forward to seeing more and more of these out at the track up here in norcal
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 10-14-2015, 06:57 AM   #1133
Josh-n-ya's Avatar
When using the plastic gears in the diff. Do you guys sand the back of the cone gears a bit. My gear mesh is a little on the tight side. Oh didn't see a measurement on shock length. Anybody know?
Old 10-14-2015, 08:37 AM   #1134
racer x 1's Avatar
Trader Rating: 27 (100%+)
Anyone know where i can find an evo6 currently? All ive seen are tb04r's in japan
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-14-2015, 08:40 AM   #1135
Ph3nyx's Avatar
i sand them about 0.1mm , works like a charm !
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 10-14-2015, 08:43 AM   #1136
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
there is one on Ebay Black Version for 349.00
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-14-2015, 08:58 AM   #1137
Josh-n-ya's Avatar
Thank you. Also in building the diff. It says per instructions to use the metal shims on the outer portion of diff. But it looks like there is two metal ball bearings that look to be a similar size. Is that an option to use the regular bearings or stick with the metal shim inserts?
Old 10-14-2015, 09:54 AM   #1138
Leester's Avatar
Trader Rating: 21 (96%+)
Sanding the gears because it is molded part is a "sand and fit til it's right" kind of thing for me. Depending on the part, one piece may take a bit more finishing than another. As for shock length I measure the shock shaft from the bottom of the lower shock cap to the plastic shock holder. I usually go 11.5mm on the short shocks.
Leester is offline   Reply With Quote
Old 10-14-2015, 11:07 AM   #1139
I just sand the gears smooth on the back so that all the flashing is gone. The diffs are super smooth.
The shims are needed to hear the gear lash (mesh) correct between the ring (diff) gear and pinion (input gear) inside the gear box (bulkhead). Every car will be different. All four of my gear boxes are different on my two cars. It's trail and error. You want just a slight tick of play between the two gears.
I measure the shocks with a set of calipers inside the upper and lower eyelets "stretching" the shock. I run mine at 57mm length. That's a little longer than needed, but it allows for a wide range of droop setting to be used.
Old 10-14-2015, 12:53 PM   #1140
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Anyone know where i can find an evo6 currently? All I've seen are tb04r's in japan
Guessing a Black exo-six is in your future
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
