Like Tree24Likes
Old 10-03-2015, 01:42 PM   #1081
Aitutaki's Avatar
Originally Posted by OVA View Post
Hello
Mine is 1465 with 72Gm. added to balance and 1450 min weight..
6000 nano- tech lipo,hobbywing V3 esc.,savox,TP 21.5,ride tires,HPI bodies
okay, our min. weight is 1380g.
so i will some lighter Lipos a try , to loose about 40g, that seems ok, and 1400 will be near to 1380....
Aitutaki is offline   Reply With Quote
Old 10-03-2015, 02:02 PM   #1082
pullstarter's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MikeR View Post
Very true. And also the gear diffs weigh about 30gr-35gr each (depending on steel or plastic internals)... which is why we ran spool and ball diff for 17.5!
Do you have the part number for the ball diff for these?
Cheers
Simon
pullstarter is offline   Reply With Quote
Old 10-03-2015, 02:27 PM   #1083
CL
CL's Avatar
Trader Rating: 32 (100%+)
Cheers
Simon
http://www.tqrcracing.com/shop/produ....asp?p_id=6983
CL is offline   Reply With Quote
Old 10-03-2015, 03:17 PM   #1084
Thank you!
Old 10-03-2015, 09:39 PM   #1085
Johnn27's Avatar
Trader Rating: 71 (100%+)
Questions?? Converting TB04 to the EX06 chassis suspension shafts????
Ok maybe someone who has converted a tb04 to the ex06 chassis can answer this? I am looking at my TB04 manual and the stock suspension shafts are 46mm front and rear , the EVO6 has 46mm shafts in the rear and 43mm shafts in the front, When I convert my tb04 over to the exo6 chassis will I have a problem with the stock tb04 46 mm shafts in the front?
Johnn27 is offline   Reply With Quote
Old 10-03-2015, 09:58 PM   #1086
CL
CL's Avatar
You also need the tb04 parts pack for the conversion.
http://www.exotekracing.com/exo-six-...ix-conversion/
Old 10-04-2015, 12:08 AM   #1087
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
I did..I am using the DCJ in the front ,it might be the 44mm or 46mm ,,So I have to look again tomorrow...sorry
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-04-2015, 08:05 AM   #1088
Johnn27's Avatar
If you are referring to the front axles I am using my 44mm rears from my old 417 and the same 417 front dcj in the front but using 42mm axles ,these parts are the same as are included in the evo6 . it is the inner hinge pins/ suspension shafts that I think I may need to replace , I have the exotek conversion and tb04 parts pack I will review the parts included to see if that resolves the issue .
Old 10-04-2015, 12:50 PM   #1089
theproffesor's Avatar
Trader Rating: 57 (100%+)
I was able to get the 17.5 put all together with electronics, tires, and body. With a 5000mah batt the car comes in at a perfect 1385g. The weight balance is split 50/50 left to right. But running bout 40g heavier in the rear.
Since I'm stuck inside because of all this rain in South Carolina (should have bought an RC boat to have some fun), maybe I can get a new body painted up too.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-04-2015, 03:29 PM   #1090
OVA
OVA's Avatar
Okay mine is 44mm in front
Old 10-04-2015, 07:33 PM   #1091
Johnn27's Avatar
Thumbs up
Looks like the exotek tb04 parts pak gives me 42mm suspension shafts and the ev6 front suspension shafts appear to be 43mm?
I guess its just a few more or less spacers shimming the shaft?
Old 10-04-2015, 08:37 PM   #1092
lbckevin's Avatar
Trader Rating: 91 (99%+)
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-04-2015, 09:30 PM   #1093
MikeR's Avatar
Trader Rating: 15 (100%+)
Use a 1mm shim at the front just like the set up sheets already posted.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-05-2015, 03:02 PM   #1094
Both cars built and ready to put on the track. Hopefully I can get the lids painted up before this weekend. I can always run my old bodies, but a good looking car on the inside deserves a good looking exterior.
Old 10-05-2015, 04:23 PM   #1095
Emaculant's Avatar
How are the Evo 6's doing on high grip carpet?
Emaculant is offline   Reply With Quote
