Like Tree11Likes
Old 09-29-2015, 11:06 AM   #1066
Leester's Avatar
Trader Rating: 21 (96%+)
[ATTACH]1320207[/ATTACH
Here's a pix of Rod Canare's electronics on his EXO6 from the ROAR On Road Paved Nat's. More information and photos can be found on the Exotek website
Exotekracing.com. Look under products, Tamiya and then the EXO6 kit. You will find setup's of Rod's and my EXO6 there along with more photos of the chassis.
Leester is offline   Reply With Quote
Old 09-29-2015, 11:58 AM   #1067
theproffesor's Avatar
Trader Rating: 56 (100%+)
What sway bar stay is that? Is it from the 418? Or 419?
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-29-2015, 02:25 PM   #1068
Trader Rating: 18 (100%+)
Just put my Evo 6 up for sale for cheap. Look for it in the for sale section!
TamiyaMatt84 is offline   Reply With Quote
Old 09-30-2015, 10:29 AM   #1069
Leester's Avatar
It's the sway bar from the 418 or 419. They are the same
Old 10-02-2015, 12:51 PM   #1070
Put the race ready EXO 6 on the scales last night. And while I haven't balanced it out yet, this car is coming in at a hefty 1465g. If I wasn't racing USGT I would be concerned. Had anyone one else noticed this car is a bit heavy?
Old 10-02-2015, 02:30 PM   #1071
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
It's probably your battery, motor, body, etc..... I had to add 36g to my evo 6 at the Nats and I ran it stock,
King of B Main is online now   Reply With Quote
Old 10-02-2015, 02:35 PM   #1072
6500 mah smc batt. Just stock esc. Hobbywing motor. Savox 1251, spektrum micro rx. And pf-10 body. But I am not running any aluminum or titanium screws.
Old 10-02-2015, 02:37 PM   #1073
MikeR's Avatar
Trader Rating: 15 (100%+)
Very true. And also the gear diffs weigh about 30gr-35gr each (depending on steel or plastic internals)... which is why we ran spool and ball diff for 17.5!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-02-2015, 03:04 PM   #1074
Plastic gears and spool up front
Old 10-02-2015, 09:21 PM   #1075
My motiv motor was way lighter compared to my R1motor.
Old 10-02-2015, 09:52 PM   #1076
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Hey
I need the basic carpet set up for this Exotek EVO6 ..Thanks
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-03-2015, 03:03 AM   #1077
Aitutaki's Avatar
same here.
standard kit + exotek exo-six
kopropo rsx10 servo, light kopropo receiver , lrp spx zero ESC , but having 1440g
with HPI Mustang GTR Body and Silverback 6300 Battery -
The Car with electronics is 1004g , battery 310 , the rest is the body...
Aitutaki is offline   Reply With Quote
Old 10-03-2015, 07:47 AM   #1078
Originally Posted by Aitutaki View Post
same here.
Buy a 5000mah battery . It's plenty of battery . We just ran a race and mains were 10 minutes and we ran 3 mains and my defy 5000 lipo had no problem.
Old 10-03-2015, 07:59 AM   #1079
Ova, I'm starting with kit setup as far as camber links, hinge pin blocks and shock location. I'm going with 1 degree front toe out, -2 rear camber, -1.5 front camber, 5mm ride height front and rear, 2mm over ride height rear droop, 1.5 over ride height front droop. 37.5 front shock oil (associated brand). 35 weight rear (associated brand). That's for both USGT and 17.5.
The differences come in with diff, 2k USGT, 3K 17.5. And springs. I run RSD carpet springs. USGT it's pink front blue rear, 17.5 it's light blue front and pink rear.
That's going to be my starting point. I'll get some track time in next weekend and see how it goes.
Old 10-03-2015, 08:07 AM   #1080
OVA
OVA's Avatar
Hello
Mine is 1465 with 72Gm. added to balance and 1450 min weight..
6000 nano- tech lipo,hobbywing V3 esc.,savox,TP 21.5,ride tires,HPI bodies
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
