Like Tree23Likes
Old 09-06-2015, 09:32 PM   #991
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by OVA View Post
.5 sec..ouch that's not good..
I did moved the batteries in two different position .farther back ,the car is more stable on throttler in the rear ,but push into the corner at slow speed..So I shifted all the way forward and it got better steering but you have to use brake a little ..
Maybe I should try thinning diff oil or take some oil out some ,so it wont be too thick
I was using 2k in my diff what are you running? -this week I'm changing bodies to the new z28 protoform last weekend I ran the older PF Camaro body with a Tamiya low down force wing. That might be why the car was a little edgy?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-06-2015, 10:24 PM   #992
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
I am using 1500cst ..the new camaro is a good choices
I have the HPI carerra GT bodies
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-10-2015, 01:01 PM   #993
theproffesor's Avatar
Trader Rating: 57 (100%+)
I just purchase 2 conversion kits and am about to get 2 EVO 6's to go with them. What are the most common broken parts and what should I upgrade right out of the box?
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-10-2015, 01:21 PM   #994
The car is pretty bullet proof. I would a spare ring a pinion front and back a when building the diffs take your time shimming the diffs to get the lash correct. Then c-hubs f/R spindle carriers and a-arms that's all I can think. Of. I thought of one more thing a front spool instead of the front diff but that is personal preferences.
Old 09-10-2015, 06:53 PM   #995
What size shims should I order so I can have them on hand when I do my initial build? I have had shaft drives in the past and had no issues with shimming. Just have to do it right. Does the kit come with both a front diff and a spool? I thought the black edition only came with a spool. I run a diff in my USGT car now, and a spool in my 17.5.
Old 09-10-2015, 09:01 PM   #996
OVA
OVA's Avatar
EVO 6 come with spool as box stock,no front gear diff..
Old 09-11-2015, 10:02 AM   #997
Where is the best place to get Tamiya parts from here in the US?
Old 09-11-2015, 10:09 AM   #998
Where is the best place to get parts from here in the US?
tqrcracing
malkiy is offline   Reply With Quote
Old 09-12-2015, 07:05 PM   #999
What brand spur gears will fit the Exo 6 conversion, and will it handle a 88/56 ratio?
Old 09-12-2015, 08:41 PM   #1000
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
I got these for my EXO5..
http://www.tqrcracing.com/shop/produ...&s_maker_id=98
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 09-13-2015, 06:30 AM   #1001
Ok thanks for all the info so far. I have looked on petite RC but can't find a 17.5 carpet set-up. Can someone post one or a link to one?
Thanks.
Old 09-13-2015, 07:24 AM   #1002
Thanks.
Could some one just post a setup all of these setups are from when the EVO6 was released. Setups had to improve or change since 2 years ago.
Old 09-13-2015, 07:45 AM   #1003
Just read back a few pages and saw where Mike from Exotek is going to post up some set-ups after the Nats this weekend.
Looking forward to getting the kits in and getting them on the track in the next month or two.
Old 09-14-2015, 09:15 AM   #1004
rtypec's Avatar
Here's the setup from this past weekend. The Exo6 chassis is a little stiffer than the stock chassis and is a little more free...otherwise, setups for both Evo6 and Exo6 are identical.
rtypec is offline   Reply With Quote
Old 09-14-2015, 11:39 AM   #1005
Thanks. Hope the car performed well. I am really looking for carpet set-ups though
