Like Tree24Likes
Old 08-30-2015, 09:02 AM   #961
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Aitutaki View Post
What will be the advantage?
EXO6 has 2 gears less,with 2 less gears the car will have less parasitic power loss in the drive train.. The motor is not hanging a.mile out the driver side of the car, that effects weight distribution. I ordered a EXO6 I am looking forward to racing it. The gear noise in my EVO6 was a real draw back for me I always thought the noise was sound of horsepower being loss.
I always servo taped my batteries down and i would move tthem towards the rear to get better balance so the sliding battery mounts is a big plus for me in the EXO6 chassis.
I race gt3 we use USGT rules except we run slicks with 21.5 motors the less noise and drag in the drive train relates directly to faster lap times I am so pumped to try EXO6 I really love my EVO6 even better then my 418.
The EXO6 is the design Tamiya should have used in the first place for the EVO6! With the corner speed the Awsomatix cars have it should have been a no brainer for Tamiya to build modern shaft drive car that isn't as fragile as an Awsomatix is. I'm hoping to get the corner speed of an Awsomatix and the reliability of a Tamiya.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-30-2015, 12:40 PM   #962
robk's Avatar
Trader Rating: 22 (100%+)
The Exo conversion is pretty fast. I have seen the test car in the hands of a good driver with a 17.5 and it is excellent.
Old 08-30-2015, 01:16 PM   #963
Aitutaki's Avatar
thanks guys, i am really thinking about buying the exo six , espacially the expected less noise sounds great
unfortunately, shipping to EU ist quite expensive
Aitutaki is offline   Reply With Quote
Old 08-31-2015, 07:53 AM   #964
masterhit's Avatar
Trader Rating: 15 (100%+)
Hopefully Exotek can chime in on this,
Any idea if the 54052 Universal center shaft (TB03 upgrade EVO V standard) will work with the 6 conversion?
Thanks!
Mike
masterhit is offline   Reply With Quote
Old 08-31-2015, 12:44 PM   #965
EX06 will be the same as a tc4 with bling..... Interesting how manufacturers are going back to the old AE design...... Cheers...
bertrandsv87 is offline   Reply With Quote
Old 08-31-2015, 04:46 PM   #966
Trader Rating: 8 (90%+)
Thanks!
Mike
No, because the shaft is longer than the standard EVO6/TB04 shafts.
However, if you buy the Exotek EXO-FIVE DRIVE CUP, then I don't see why it won't work.
TenzoR is offline   Reply With Quote
Old 08-31-2015, 05:53 PM   #967
MikeR's Avatar
Correct, replace with the EXO-FIVE drive cup if using TB03/Evo5 shaft.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-01-2015, 07:18 PM   #968
Mike, when and where will you be publishing the EXO 6 conversion manual and setup suggestions?
Old 09-01-2015, 07:43 PM   #969
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
My Awesomatix is more durable than my 418. And the Evo 6 pretty much has 418 suspension.
The Exo 6 looks really cool though, I would have totally considered it if I didn't have an Awesomatix now.
Dan is offline   Reply With Quote
Old 09-01-2015, 09:50 PM   #970
MikeR's Avatar
The build sheet are already listed on the EXO SIX page;
http://www.exotekracing.com/exo-six-...sion-for-evo6/
Set up sheets after Roar Nats.
Old 09-02-2015, 01:54 AM   #971
Quick question can I use a front diff on this car??
BigAl.J81 is offline   Reply With Quote
Old 09-02-2015, 05:15 AM   #972
Considering it shares the TB04 diff cases, yes, you can run any diff offered for the TB04 on the Evo 6.
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 09-02-2015, 05:36 AM   #973
I shouldn't have said durable on our track we were having a problem getting over the bumps in the entrance to the sweeper. We couldn't get the dampening right if we set it to get over the bumps in the sweeper it would compromise the handling in the rest of the track. The cars that use conventional dampening system i.e. fluid filled dampeners and springs work over the bump.
You are right about 418 c-hubs if you can't stay off the falls your done. My friend sold his 418 for that very reason 2 c-hubs in 2 heat races, he was done with his 418.
Old 09-02-2015, 07:43 AM   #974
theproffesor's Avatar
Trader Rating: 57 (100%+)
Other than tub vs carbon chassis, what is the difference in the tb04r and the EVO6. Do they share the same suspension geometry and parts? Looks like the cheapest route for the EXO 6 is a tb04r and the conversion. Fewer left over parts that will be hard to sell.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-02-2015, 09:39 AM   #975
JayL's Avatar
Thats why they came out with the new d2.1 dampers you can fill yourself. Works great on bumps now.
Sure the EX will be awesome Exotek stuff always is!
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
