Like Tree23Likes
Old 04-16-2014, 07:31 PM   #76
Send a message via AIM to racer034life
So whens the release date...?
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 04-16-2014, 09:46 PM   #77
Smile
Exactly like my tc4.1 except for the short shocks !!! This Car should do great !!!!
Originally Posted by cplus View Post
Because the 418 is belt driven....?
Means they can have a pinnacle (in their range) of each style.
Let's look at the positives for 17.5 blinky
- low weight (the plastic bulkheads are probably lighter than an alloy one?)
- stiff, but compliant chassis
- relatively low maintenance, easy to adjust gear diffs
- excellent suspension arms and mounting
- class leading, low COG dampers
- decent modern geometry (you would expect)
- shaft drive punch
- lots of adjustability (susp blocks for example)
- excellent DCJs in the front and proven reliable rear shaft design
Assuming the FDR can be made to work it will definitely competitive when power isn't crazy and won't be flexing the hell out of the chassis.
bertrandsv87 is offline   Reply With Quote
Old 04-17-2014, 03:46 PM   #78
Hebiki's Avatar
Trader Rating: 26 (100%+)
read all 6 pages.
excited about this car.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-18-2014, 07:32 AM   #79
Originally Posted by Hebiki View Post
read all 6 pages.
No you're not, you'll wait for Oliver to buy it and borrow it from him.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 04-21-2014, 06:29 AM   #80
kentech's Avatar
Here you see a few more details of the TB Evo 6.
If you want to see a larger version check my blog.
Quality of the pictures is what it is...
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 04-21-2014, 07:11 AM   #81
Simmi's Avatar
Thank you Kentech
Hope you will soon see color images, then you can use also make a proper Picture of the car. I cannot wait anymore
Kentech did you know when the kit will be released?
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 04-21-2014, 08:02 AM   #82
kentech's Avatar
Originally Posted by Simmi View Post
Thank you Kentech
TB Evo 6 release should be June. No exact date yet.
Old 04-21-2014, 09:15 AM   #83
masterhit's Avatar
Trader Rating: 15 (100%+)
So from Kentechs pictures (I'm eternally grateful for his site btw);
Flipped 418 steering arms to clear the shaft.
Cantilevered spur and and bevel gear mount to let the motor move in (at least it appears) and use a traditional style motor mount.
Good stuff!
masterhit is offline   Reply With Quote
Old 04-21-2014, 11:21 AM   #84
looks like they got the gearing issue solved
but I'm worried about how the upper deck is mounted. Looks like there is no bulkhead support, kinda like floating on raised posts...
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 04-21-2014, 06:41 PM   #85
t4m1y4niac's Avatar
this configuration makes the motor far away from center line.cant wait to see the handling of this car.
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 04-22-2014, 04:24 AM   #86
TB03Racer09's Avatar
hahaha shorty motors anyone?
I'm also want to know how far out the motor sits and if the tb04 pro II has a similar motor mount as the cad pictures of it show us a beautiful gearbox cover...
TB03Racer09 is offline   Reply With Quote
Old 04-24-2014, 10:54 AM   #87
upon closer inspection over at the better pic from Kentech, a good frontal crash or read end will bend those posts that hold up the upper deck
redbones is offline   Reply With Quote
Old 04-24-2014, 11:23 AM   #88
FMW
FMW's Avatar
The EVO 6 motor mount is very unique compared to the way we did it on the TB-04. You will have far greater gear ratio options compared the the standard TB-04. Though, you can use the Exotec Alum motor adapter for the TB-04 to get more gearing and we are also releasing one at a later date.
FMW is offline   Reply With Quote
Old 04-24-2014, 06:29 PM   #89
Fred- whats the chances if getting my hands on this car for Reedy?
Juan Aveytia is offline   Reply With Quote
Old 04-24-2014, 07:39 PM   #90
The EVO6 design only for stock motor?
Can run in modify motor? (such as 6.5t~4.5t +boost/turbo)
Don't know the bevel gear strength ?
e58105419 is offline   Reply With Quote
