Like Tree3Likes
Old 08-21-2014, 03:42 PM   #571
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Simmi View Post
Here it is my finished EVO 6 and my first Setup Sheet and Outdoor run
Simmi i checked out your set up on Petit RC. What was your reasoning in using HPI blue springs. Instead of the silvers in that most guys run on their 418. I ran my EVO 6 with silver HPI springs and it handled good I thought. I have was wondering what the difference was? I will try some blues this week.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 08-21-2014, 10:40 PM   #572
Simmi's Avatar
Hi Vivo, I will post some new Sheet after my first race in two weeks.First the EVO must be a whole day reliably.
On Petit RC I see a second Sheet and I don`t know from where it Comes
You should use in the rear C und C Blocks because the car drives very fast in corners and out of the corners. I use at my TRF 418 C and D in the rear. 2 Camber around very stabil and smooth driving. Front C and B Blocks.
Only reason why I use Blue Springs? My TRF like the Silvers too
The Blues just a bit softer and also good onroad.
Last time I had problems with the Bevel Gears in the Front Spool. Shit shiming in the manual.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 08-21-2014, 11:39 PM   #573
metalnut's Avatar
Trader Rating: 36 (100%+)
Can you elaborate on this? What did you do instead? Anything we should watch out for or double check?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 08-22-2014, 04:07 AM   #574
spring71's Avatar
Smile
We just got new EVO6 parts today at TQ.
http://www.tqrcracing.com/shop/parts...arts_p_id=8033
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 08-22-2014, 06:44 AM   #575
Simmi I raced my EVO 6 last weekend it turned faster laps then my 418 in USGT and was 3 seconds from turning 22 laps which is the USGT lap record only one driver has hit that and he had a perfect race. My race a little tougher we had a mixed field we didn't have enough experts to have our on race so we had 5 drivers that are unpredictable.
My car received extra tech inspection to make sure it was in blinky. The car turn consistent laps almost a within .5 second . EVO 6 is a fast car!
I have one more question what is the reason you are running .5mm shims under the suspension blocks. Most of the 418 set ups I see on Petit RC they are running no spacers under the blocks,I at my EVO up that way.I was wondering if you know the difference?
Old 08-22-2014, 08:41 AM   #576
niznai's Avatar
One possibility if for higher roll center, hence less roll.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-22-2014, 09:09 AM   #577
metalnut's Avatar
Actually, removing spacers lowers the blocks and so lower the arms, which lowers the roll center. That makes the car roll more and produce more grip, but makes it a little lazier.
- Ricky Bobby
Old 08-22-2014, 09:41 AM   #578
niznai's Avatar
Read the question again.
Team Greasy Weasel
Old 08-22-2014, 12:04 PM   #579
metalnut's Avatar
So I just got word that Exotek is working on a longitudinal motor conversion for the EVO.6, should be nice.
Now if someone can step up to make us some aluminum bulkheads.
- Ricky Bobby
Old 08-22-2014, 10:52 PM   #580
Simmi's Avatar
I used 0.1 or 0.2 mm more, do not remember exactly. But holds up now. Tomorrow I test the whole day the stability.
Had luck, almost milled the front gears
Team Yokomo YZ2 CA
Old 08-22-2014, 11:06 PM   #581
Simmi's Avatar
@Vivo
Yes, the EVO is a very fast car that`s why I didn`t sell it
I had much Problems with the shiming all the time.
0, 5 shiming under the front Suspension Blocks? I wonder
Team Yokomo YZ2 CA
Old 08-23-2014, 12:31 AM   #582
metalnut's Avatar
A few pages ago I mentioned that Kimbrough spurs work but come very, very close to the motor mount. So much so that you have to shim them away so they don't rub. Well, instead, I've now installed an ARC spur, namely the 74T: http://www.arc-rc.com.tw/products_spare4080.html
The ARC spurs are gorgeous, CNC machined, and very thin. Honestly, these are the nicest spurs I've ever seen, right up there with the Xray. At 74T, it will give me plenty of gearing options for VTA.
- Ricky Bobby
Old 08-23-2014, 06:33 AM   #583
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Metal, thanks for sharing that spur link. I need a VTA spur as well. Fits perfectly?
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 08-23-2014, 10:45 AM   #584
Hi guys, not sure if it was me suffering from this problem only. I raced my Evo 6 at 13.5T boost class in my local club. I've raced for 3 club meetings and "lucky" enough to have the bevel gears in the gear boxes milled by all 3 race days. Whenever the new bevel gear was reinstalled, I had checked the drive chain and it was free to a satisfactory level.
Now I'm thinking of switching to Evo 5 bevel gears (as mentioned above). May I ask if the modification work being difficult or not? Any advice for me about the modification work then? Very much thanks for your kind input!!
donatelli is offline   Reply With Quote
Old 08-23-2014, 10:50 AM   #585
metalnut's Avatar
A somewhat tight but in my opinion perfect fit, yes.
- Ricky Bobby
