Like Tree23Likes
Old 08-18-2014, 01:01 PM   #556
Originally Posted by metalnut View Post
They rock side to side along the middle when held together, and the top case has a smaller-than-necessary opening for the smaller of the two input shaft bearings.
I have the same problem before and i order 2nd set. still the same. So i just use as is
Tamiya Fan
Still have: TB-03, TA05V2, TA06, M05, F201, F104V2, FF01, FF03, Jeep, TXT, King Hauler with oil tanker trailer.
And, TC-3 and Pro 2
TamiyaW1688 is offline   Reply With Quote
Old 08-18-2014, 02:30 PM   #557
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I need to know what suspension blocks come on a evo6.?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-18-2014, 02:49 PM   #558
-jacob-'s Avatar
My Tamiya friend has an EVO 5 that free-spins for over 20 seconds with wheels on, it's a work of art. His EVO 6 is nice too, but not nearly as free. He's having problems getting his TB04 to be free at all, so I think this is a common issue.
I ordered two sets of carbon reinforced cases from Banzai (so, total of 4 cases), and all of them have the same problem. They rock side to side along the middle when held together, and the top case has a smaller-than-necessary opening for the smaller of the two input shaft bearings.
My friend actually took my original warped case to TCS nationals to show to a Tamiya representative. I'm hoping something good will come out of that for all of us
In the meantime, maybe I should try the EVO 5 gears. Are they a direct replacement for the EVO 6 gears, or should I get additional parts to make them fit? Lots of sanding?
Troys evo 6 spins for about 9 seconds.
he did get his TB04 to spin for 5 seconds.
Id like to see how the TB04s do in the Nats... then again its asphalt and they dont use 25.5 motors there... which is where a shaft comes in handy.
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 08-18-2014, 02:59 PM   #559
metalnut's Avatar
Trader Rating: 36 (100%+)
0* front (1B and 1B), and 3* rear (1XB and 1D)
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 08-18-2014, 03:01 PM   #560
metalnut's Avatar
Well, let's see if I can achieve the 9 second mark. I think with a front spool it'll be close, but with front and rear diffs it most likely won't make it. But that's where I'm hoping for the break-in to help, or perhaps switching to EVO 5 gears.
- Ricky Bobby
Old 08-18-2014, 05:17 PM   #561
I'm going to try to chase half a dozen Awesomatix this season (stay out of Scale Spec, Mike )
Driver skills > chassis / drivetrain.
John's tires > all.
-Mike
Old 08-18-2014, 07:18 PM   #562
metalnut's Avatar
- Ricky Bobby
Old 08-19-2014, 01:23 AM   #563
Electr0n's Avatar
The large 39T bevel gear is a direct replacement. the 16T smaller bevel gear has to be sanded down or like i did, carefully drill out from the top with a 10mm wood drill so the c-clip will fit.
At least the front spins more freely with the EVO 5 spool and gears.
Andre
M-03, M-05, TB 03 (R+), TB-04 Pro (R), TT-02 S, TRF 417X, TRF 417V5, TRF 418, TRF 419, All TB EVO Chassis, TRF 414 and .....
Electr0n is offline   Reply With Quote
Old 08-19-2014, 03:28 AM   #564
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
will Tamiya or Square be making an option part for a Blue Aluminum Bulkhead for the Evo 6
buboy28 is offline   Reply With Quote
Old 08-19-2014, 07:49 AM   #565
metalnut's Avatar
I have money in hand for the first manufacturer to do so
- Ricky Bobby
Old 08-19-2014, 08:29 AM   #566
If or when someone does make aluminum bulk heads this drivetrain will really free up
Juan Aveytia is offline   Reply With Quote
Old 08-19-2014, 06:59 PM   #567
JimmyMac's Avatar
Do they make one for the TB03?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-20-2014, 01:18 AM   #568
Electr0n's Avatar
New main chassis with holes for the EVO 5 (MS) bulkheads ?
(Or extra holes in the current main chassis if possible)
>> will test if this is possible <<
Almost done rebuilding the EVO 6 with EVO 5 bevel gears and alu bevel gears for the spur transmission. almost 8 seconds of spinning without the bearings being treated. Only thing not yet tackled is the amount of play on the bearings of the spur gear holder.
Andre
Old 08-20-2014, 02:08 AM   #569
buboy28's Avatar
I know Square made the blue and red Aluminum one for the Evo-03 i just ca'nt remember if it will fit the TB-03
Old 08-20-2014, 04:44 AM   #570
masterhit's Avatar
Trader Rating: 15 (100%+)
I have a friends car up to 10 seconds (verified on my phone) with the stock gears and gear boxes.
It required a lot of dremeling of the gear boxes, mainly front as the spool was tight, and more shimming and re-shimming than I care to remember.
I think I have a solution for the wobbly spur mount miter gear. I used a 3mmx6mm bearing in the miter gear after boring it out for the depth of the bearing. The layshaft at the end is about .124" so will require a tiny bit of reducing.
The blue spur mount will also need to be permanently modified to expose the reduced diameter section of the layshaft. I'm going to cut it down to the miter gear key and then use shims to set the plunge of the miter gear.
Fun stuff!
Mike Slaughter
masterhit is offline   Reply With Quote
